2013 TC2 Tc & CEL Same time..?
I just installed Weapon-R headers with CEL eliminator and Megan racing drift spec catback exhaust system the car runs just fine and I drove it around a day since installation but today my CEL and traction control off light came on and I can't get them to go off simply restarted the car and the traction control won't turn back on anyone ran into this?
Should've gone with the green header instead. I've been avoiding weaponr for the reason I don't feel comfortable installing something that causes a cel and requires a cel eliminator to be installed to fix their issue. It sounds like you now don't have a cat so thats probably why you can't get the lights to go off. Just my thoughts, I'm not a mechanic so it's just a shot in the dark. Good luck on solving the issue
Alot of things can cause both lights to come on at the same time. You need to to go autozone and have your codes read for more details.
People have installed the Weapon-R headers with CEL eliminator and have had no problems.
Have you tried resetting the ecu? Unplug the battery, wait a few mins and drive it around for awhile to reset it and see it comes back. This is important to do.
I'm 99.9% I caused it myself I put the CEL elim on the primary sensor on the header itself (before the cat woulda been) so I just removed my s-pipe put the eliminator on the secondary sensor (after cat) and cleared out my ECU so I guess ill know here in a few days what happens I appreciate all the free back
you are supposed to install it on the s-pipe not the header.
i read this: http://clubsciontc.com/forums/mainte...minator-40897/
i have a takeda intake and this exact same thing happened about a week ago trac off light came on and check engine light too had the code scanned and it wasnt anything related to traction control then one day i spun tires leaving somewhere and the light just said hey i liked that and went off
Traction control also quit working earlier weird but I put the sensor in the s-pipe where it belonged 30 miles so far no light 20 more to go and we will see if I need to visit stealership
OpTicaL
Sep 16, 2015 10:25 AM
