Power loss at around 4k?
This is baffling me. In first gear, around 4k rpm it feels like the engine hesitates at WOT for s split second. Only at WOT, and only in first gear. Could this be the TCS?
Its almost like hitting a rev limiter. The tach freezes for a slight moment then keeps pulling hard to redline.
Any ideas?
Any ideas?
The traction light hasn't come on, but it almost feels like the tires are breaking traction. Wouldn't that be more likely to happen more toward the take off than at that rpm range though? Its consistently at the same engine speed every time.
I'm going out in a little bit, I'll try without the control on
dual vvt-i. its the computer changing the cam timing to produce more power, you can really hear it with a cai because it really starts opening up the air flow and adding fuel. and yes, it will break your tires loose. if your on a slick road itll also do it in second. just press and hold the traction control button. trac off' will appear immediately, and after about 4-5 sec the traction control image will appear also. you shouldnt have a problem with it after that
RY_TC07
Jul 18, 2017 05:18 PM
Atticus_the_XB
Apr 13, 2015 06:46 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
