Here is a video of my kit I painted the manifold with VHT Flame proof ceramic coat in black and baked it myself. I replaced the intake filter and painted the ic piping. It was a used kit the guy who sold to me said it had had 6k miles on it. The turbo look good no oil or shaft play. So far the map that was in the fic is running ok. Next i will get it dyno tune in a week or so. It run and feel like stock until you punch on it. Im at 4 psi untune and it pulls hard, hopefully when im tune and turn up the boost a little it will be how i wanted it to be.
Niiiiiice!!!
Not yet. Fuse box is half apart. Have to replace fusile link. Its a pain to do.
Quote:
Idles at 16-18 and cruise at 14-15 and boost at 10.Originally Posted by my06tc
very nice..looks like its running very lean.. whats the afrs at wot..i know its not tune...but curious
Drived like stock even though lean at idle. Boost is rich and cruising is perfectly fine at 14-15 afr. This was the original owner map just a lil tweeking it will be perfect.
Originally Posted by Rydrdg
Idles at 16-18 and cruise at 14-15 and boost at 10.Drived like stock even though lean at idle. Boost is rich and cruising is perfectly fine at 14-15 afr. This was the original owner map just a lil tweeking it will be perfect.
if you know how,add some fuel at idle.....but overall....nice whip.....do you have open dump
Quote:
Does the fic auto connect to labtop, do i need a software. I want to try add fuel during idle.Originally Posted by my06tc
yes,you need the aem fic software and the usb drivers....think you can download them from aem website....once you have the correct ver of software and drivers,just open up software,connect usb to laptop and go from there...at least thats how its done in the 1st gens and the fic"s
Quote:
Back in action. Fusible link was bad. Replaced and all is back to normal.Originally Posted by Rydrdg
Thnx man. Did u ever fix your car yet?
Quote:
your idle afrs are so low because you probably have an exhaust leak. its pretty hard to tune idle that low on a piggy back like FIC. usually the stock pcm will fight for 14.7 and youll get fuel trims instead. and from your video, it sounds like you might have a leak.
Yes your stock clutch will hold 10 psi my cars been boosted on stock clutch and flywheel for over 3k miles no issues
Quote:
Any lag between your shifting?
no lag feel like stock car until you punch it. my manual boost control is set to low boost and I can't get over 4psi. I am getting it dyno tune this Saturday and turn up the boost to the max. I will have video uploaded by next week.Originally Posted by Reticuli
Nice setup.Any lag between your shifting?
