Scion tC 2G ICE & Interior In-car entertainment and electronics...
2011 tC Steering Wheel Control Eonon Head unit
Old Feb 24, 2013 | 12:49 AM
ajemptage's Avatar
Default 2011 tC Steering Wheel Control Eonon Head unit
Hi guys and gals, this is my first post and i have just started upgrading my 2011 tC.
So here is the situation, i just got an Eonon G2103V head unit and it has universal steering wheel control option, it has three wires:
Steering wheel GND, Steering Wheel key1 and Steering Wheel Key 2,
Once you plug in the correct ones you then use the built in programming function in the unit to assign the keys to whatever function you want.
This brings me to my question, does anyone have a wiring diagram or color coded list for the Steering Wheel control plug on the wiring harness?
Or better yet does anyone know the wires that need to be attached?
________
Old Feb 27, 2013 | 02:31 AM
ajemptage's Avatar
Default ...
Ok can anyone at least tell me if this car uses a CAN BUS type swi or an AD conversion?
Just so i know if i have to buy an adaptor or the axxess
Thanks
Old Feb 28, 2013 | 09:10 PM
ajemptage's Avatar
I figured it out, so for anyone else who is looking for the same answer i will list it below, it uses the same pin-out as most toyotas since 1980.
anyway, the wires are as follows:
GRND is pin 6 if looking at the pin side of the 20 pin white connector,
Key 2 is pin 7
Key 3 is pin 8
I found the pin-out here:
http://www.castulucci.com/projects/c...ors/index.html
Thanks everyone!
Old Apr 16, 2013 | 12:48 AM
apr4176's Avatar
Default 2013 Scion tC2
I have the Xtrons head unit for my wifes tC. Will this wiring work for the steering wheel controls? On the 2013 there is a 28 pin connector on the stock unit, can't remember about the 20 pin will have to pull the unit again.
Also on the metra wiring harness only one of those connectors was a direct connection. The other smaller connector does not fit onto the stock connectors for the other speaker wires, these other four wires are on the 28 pin connector.
Thanks
______
evolving_machine
Oct 21, 2023 01:16 PM
evolving_machine
Jan 13, 2015 08:04 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
