Scion tC 2G ICE & Interior In-car entertainment and electronics...
Cluster Gauge Needle Recolor
Old Feb 11, 2012 | 06:37 PM
WellesleyScion's Avatar
If I recall correctly, there is only 1 LED that actually lights up the needle on the tC2.
Old Feb 11, 2012 | 07:07 PM
MightyP's Avatar
^ I'm not sure on the fuel gauge, but the 2 main needles have 3 LEDs each.
Old Feb 11, 2012 | 07:15 PM
^^^ oh good, I will have to take my gauges apart and swap a couple LEDs then
Edit: the fuel gauge is the one I am thinking about, it shares 1 LED for both the needle and the gauge itself.
Old Feb 14, 2012 | 12:21 AM
Errikos's Avatar
would you guys know if i need to paint the needles white? i just ordered the leds last night got all white with 2 red gonna put the red on the last spot of the tach needle and the last spot where the numbers are for the tach
but for that red to show up on the needle can i just paint it very slightly with white or should i go clear that maybe has some sort of sparkle to catch the color (needle will start white then transition to red near final led)
the 2 red circles are where the red leds will go, got the pic from the guide writen by Bloodborn
Old Feb 16, 2012 | 02:45 PM
Errikos's Avatar
so i did the white leds under the needles with a red for the final and painted it white and the needle only lights up white
also i had a issue with the glass screen its only showing up orange anyone know if its repairable or do i need a whole new cluster???
Old Feb 16, 2012 | 05:01 PM
MightyP's Avatar
I didn't notice this earlier.
First, you only get one color for the needle. I would suggest doing 3 white LEDs and just painting the needle the color you want.
As for the little display, there is a filter you need to remove. It will make it blue. If you want a different color, you'll need to get another filter.
Old Feb 16, 2012 | 05:34 PM
Errikos's Avatar
The problem I'm having is with the display its lit up correctly but none of the numbers are showing even when I try to cycle thru the settings, is it possible to replace the screen and any idea where it can be found? Replacement cluster is around 250$
Old Feb 21, 2012 | 01:13 AM
Errikos's Avatar
All fixed, i feel like a tard the LCD wasnt plugged all the way in i think it was mightyp that suggested it idr tho, pic doesnt do justice it transitions from orange to red CEL now white and trac off is white
broke the post off the back of the gas needle had to use contact cement to get the plastic re-attached to the needle backing, anyone know if we can put needles from other toyota in or other cars? will the pin that goes in the back be same or only the scion tc2 gauge cluster work
Old Feb 21, 2012 | 03:01 PM
GAPS11TC's Avatar
I like it!
Old Aug 12, 2013 | 07:21 PM
Zero90's Avatar
Thread is a bit old but if someone can respond, it would be greatly appreciated.
I did the needle stuff and put it back together and the needle doesn't stick well and keeps falling down. Would gluing it back together possibly help?
yhwhdesign
Jun 11, 2021 03:34 PM
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
paisatronix
Sep 5, 2015 04:13 AM
