Factory amp/HU questions
So anyway-
Can I just replace the 6x9's with some nice component ones?
Is there some reason why it wouldn't work? Is the stock 6x9 just a woofer, and has a crossover somewhere that would make the new ones not work right? I'm really not trying to replace the head unit. I just want to replace the front door speakers and use the factory amp to power them.
Thoughts?
Thoughts?
If they ( Toyota ) have made no changes to the audio system amp since sept 2010 when our car was built then I will say your amp is a band pass amp that plays from about 60 hz ( maybe ) up to 800/1000 hz range.
I can confirm this after putting a set of Focal's on the amp. straight midbass (its not even crossed over on the low end, only on the high end around 800-1000hz) Only way to get LFP is to do it on the head unit and no way to adjust the bandpass. the stock amp is pretty much useless.
Grimgrak
Aug 26, 2005 02:47 AM
