Shift Boot Help
I took apart my shift boot in my 2011 tc2 to attach a crown royal bag. I did this without taking apart the console I disengaged the shift boot and when I put it back I I cannot clip it back
◄◄Click Here to Add your Vehicle to Garage
how do I fix this?
how do I fix this?
Take out the console cover by the passenger side, then pull up the cover part where your shift cover and that little compartment is at. Make sure not to pull it hard since there are wirings under that center console. Disconnect the plugs and you should see under the plastic console that there's latches there then just simply match them. then you could put everything back.
