2013 tC Front Sway Bar Install / Removal
Hello, I'm new to the forum. Recently I purchased a 2013 Scion tC for my daughter. I have plenty of experience wrenching, but mainly on Subarus and Hondas.
The car came with a full set of lowering springs and sway bars. Since she is a new driver I am putting the car back to stock.
The strut bar was the first to go and it was a PITA to remove since u have to remove the wipers, plastic cover, wiper motor, etc.
The next was the springs, after buying the OEM bump stops, I replaced the springs. At the same time I thought about replacing the front sway bar. I started removing the bar and noticed that it would not come out.
After doing research, I found that a lot of stuff needs to come off.
Is there an easier way to remove the front sway without having to drop half the engine brace?
Hello, I'm new to the forum. Recently I purchased a 2013 Scion tC for my daughter. I have plenty of experience wrenching, but mainly on Subarus and Hondas. The car came with a full set of lowering springs and sway bars. Since she is a new driver I am putting the car back to stock. The strut bar was the first to go and it was a PITA to remove since u have to remove the wipers, plastic cover, wiper motor, etc. The next was the springs, after buying the OEM bump stops, I replaced the springs. At the same time I thought about replacing the front sway bar. I started removing the bar and noticed that it would not come out. After doing research, I found that a lot of stuff needs to come off. Is there an easier way to remove the front sway without having to drop half the engine brace?
Both the tC2 (2011-2013) and the tC2.5 (2014-2016) come with Front and Rear Sway Bars as Standard OEM Equipment. It is Not Recommended that you remove them.
Unless, You Want to drop the sub-frame for the Front Sway bar.
The Choice is Yours.
MR_LUV
personally, I would leave the Strut Bar, Lowering Springs, Sway Bars alone.
