Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Struts and Shocks
Old Jan 6, 2015 | 11:52 PM
noisy1's Avatar
Default Struts and Shocks
I have looked the web and can not find a good replacement shock and strut for our 2011 Tc.
Has anyone changed the struts or shocks and what did you use ?
Thanks
Old Jan 11, 2015 | 04:14 PM
ScionDP's Avatar
My car is still complete stock, but I've done my research. Trd front strut, tb performance rear tower brace, tb performance c- pillar brace. Shocks unsure
Old Jan 11, 2015 | 04:19 PM
ScionDP's Avatar
Thanks
by shocks do you mean coil overs or springs?
Old Jan 11, 2015 | 09:20 PM
noisy1's Avatar
We want to stay away from coil overs do to its driven all year round here in Toronto and the salt and potholes will kill then in no time.
We have over 80k and we are on our second set of struts and shocks ( A1 roads here ) now and with the resent cold the rears are freezing and its pounding the car to death!
Old Jan 12, 2015 | 02:30 AM
azztinthebox's Avatar
Bilstein has some pretty good quality parts. Coilovers aren't a bad option if you go with the correct spring rates.
Old Jan 12, 2015 | 04:15 AM
ScionDP's Avatar
I feel ya with the road conditions, im about 45 min drive from t.o. so I understand. I totally thought you were modding your ride, misinterpreted your inquiry for better quality replacement parts.
In terms of replacement parts I would only suggest OEM parts and memorize where the potholes are so you can avoid them. You might be able to find amazing quality products but your going to pay a lot for them and they'll only last you a bit longer so I'd stick with something middle grade and wont cost a lot.
In the end what would be your best solution is off-road suspension, it can take a beating and will last longer because your not completely off road. But like I was saying previously... not worth it price wise and not even sure where to get it for a TC.
Good luck with the search fellow Canadian
Old Jan 12, 2015 | 12:48 PM
noisy1's Avatar
I would love to find a Bilstein or Koni replacement for the OEM but I have had no luck.
We lowered it on TRD springs and it's mostly a nice ride in the summer but the winter cold is causing the oil or the internal valving to stick. I took the rears off and moved them by hand at room temp then stuck them out side over night and in the morning could only compress one shock 1" the other not at all.
The dealer has replaced the replaced shocks and the same problem.
So before we pound the car to death we want to cut our losses with OEM and install a good shock.
Old Jan 13, 2015 | 12:42 AM
I'm sure if you got some measurements on the ones you have now then they can match them probably. Plus if you are lowered even on springs it will cause the shock and strut to wear a little faster especially in harsher climates.
Old Jan 20, 2015 | 07:57 PM
Renike's Avatar
Thanks
i need replacements for mine as well but i have found some that work great with lowering springs as well but you can find KYB Excel G Front and rear shocks here at Scion tC2 Shocks & Struts or here KYB Excel-G Shocks & Struts
Old Jan 26, 2015 | 03:13 PM
HOODedDutchman's Avatar
Dam those look decent.
Old May 7, 2015 | 09:28 AM
keenkreations's Avatar
Or you can try Rockauto.com for shocks and struts by KYB. That is what I am running with Eibach Pro-Kit springs. Decent buy, cheap shipping.
BlingSlade
Oct 19, 2016 12:39 AM
jthistle
10
May 9, 2016 09:48 PM
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
