Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
tC2 Stainless Steel Brake Lines are now available!
Old Jun 18, 2014 | 07:36 PM
paul_dezod's Avatar
Scionetics
KAD
Default tC2 Stainless Steel Brake Lines are now available!
More precise pedal feel, no line expansion, and more crisp braking all comes as benefits of swapping out your OE rubber brake lines for our DOT approved brake lines. Full bolt on and comes with OE mounting style too!
paul_dezod
Old Jun 19, 2014 | 08:14 PM
wrelkin123's Avatar
omg I love you ordering now...
Old Jun 19, 2014 | 08:18 PM
wrelkin123's Avatar
Finally I couldnt wait for these anymore, thank you Dezod... will write a review after I get these
Old Jun 24, 2014 | 05:10 AM
wrelkin123's Avatar
the quality is good but the hoses seem a bit long i had problems with the fronts when turning the wheel, ended up taking off the top bracket, other than that everything went togother okay, alot of the rubber stuff came off the ss line, dont know if i should be concerned just the front hoses are too long.
Old Jun 24, 2014 | 10:41 AM
paul_dezod's Avatar
Scionetics
KAD
Can you post some pics of the front?
Old Jun 25, 2014 | 03:57 AM
wrelkin123's Avatar
yeah I will tomorrow.. pedal feels good though and no noises
Old Jun 27, 2014 | 04:49 AM
wrelkin123's Avatar
sorry for the delay cant find time to take the wheels of and take a pic busy working, will this weekend though
Old Jun 29, 2014 | 11:42 PM
wrelkin123's Avatar
Here is the front and back of the passenger side
Attached Thumbnails tC2 Stainless Steel Brake Lines are now available!-img_0121.jpg   tC2 Stainless Steel Brake Lines are now available!-img_0122.jpg
Old Jun 30, 2014 | 12:59 PM
paul_dezod's Avatar
Scionetics
KAD
Meh, it could be like 0.5-1" shorter, but I think we will leave it the way it is. We modeled off of an OE line setup so we know it was spot on.
Anyway, better a touch too long than too short. You know?
Old Jul 1, 2014 | 01:20 AM
wrelkin123's Avatar
lol yeah i guess, but the brackets should be changed, just a bit better but other wise im happy
Old Jul 25, 2014 | 03:02 AM
Jwong's Avatar
yea the brackets dont fit very well... I checked to see how it was after the install 3 days later and found on the passenger side it rubbed against the mount and scrapped through the outer plastic part and started rubbing on the inside metal line. Ended up taking it off the bracket and ziptie it away from everything and changed one back to oem line
Old Jul 25, 2014 | 01:34 PM
paul_dezod's Avatar
Scionetics
KAD
Which axle? Front or back?
Old Jul 25, 2014 | 07:39 PM
Jwong's Avatar
Front
Old Jul 25, 2014 | 07:48 PM
paul_dezod's Avatar
Scionetics
KAD
If it ended up that way, it was rubbing on something for sure. It's not going to happen otherwise. Have you guys pivoted the wheel with the car on jack stands and seeing what possibly you're making contact with or how the line is contacting something? Are you running an aftermarket wheel with a large width and HIGH offset? Same thing on the ground too....That is standard practice with brake lines here.
Old Jul 25, 2014 | 11:33 PM
Jwong's Avatar
Yea I had it up and Jack stands and tturned the wheel all the way and it rubbed at the back. Is it possible to buy just one front line to replace it? LOL
Brammi
Nov 13, 2016 03:46 AM
NonStopTuning
Jun 29, 2015 07:42 PM
ERZperformance
May 13, 2015 11:36 PM
CrowJenkins
May 4, 2015 04:52 AM
kdanie
9
Jul 12, 2005 01:12 AM
