Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
TRD Springs Camber Issues
Old Mar 26, 2014 | 05:29 AM
toyotamantc's Avatar
Default TRD Springs Camber Issues
I know there are a lot of threads on here regarding the rear camber issues after installing lowering springs, but people never really post on there that they are not having problems.
I just want to get an idea of how many people have lowering springs installed but DO NOT have major camber issues. I know based on the TRD Springs Installation PDF that TRD has modified the specs for rear camber but plenty of people are experiencing camber outside of the revised spec.
Any input would be greatly appreciated.
Old Mar 26, 2014 | 01:07 PM
FlintMica17's Avatar
I have the TRD springs on my '13 and have had no issues. All 4 corners align just fine and no wear patterns in 23,000 miles....
Old Apr 15, 2014 | 08:47 PM
Laguna14's Avatar
MY stock camber rear passenger is -2.0 it was .1 out of spec completely stock and Toyota has authorized an alignment shop to install a shim kit (adjustable camber lit) to please the customer. If you're stock, complain before you mod!
Old Apr 15, 2014 | 09:57 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
If you mod (lower) the camber will change again. Shims have always been around, but at not the ideal solution...far from it exactly
Old Apr 17, 2014 | 04:45 PM
russiankid's Avatar
Like KidJustin said, camber will change again and shims are not ideal. I am running -2.8 degrees camber in the rear, and so far with a proper toe setting my tires have lasted 30k miles. If you rotate them on time, the camber wear will not affect the life span of the tire as significantly as you think. I still have a decent amount of life left in my tires, I plan to take them to 40-45k before putting on a new set.
Old Apr 17, 2014 | 06:38 PM
KidJustin's Avatar
^to add to that. proper tire inflation is a must too. for stocks i beleive the front is like 32psi and the rear is 30psi
DJ_FroZone
25
May 30, 2019 07:17 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Dec 31, 2014 09:42 AM
minter66
Dec 15, 2014 01:45 PM
