new wheels..gets confusing huh?
Old Dec 28, 2012 | 02:09 PM
toytuff's Avatar
Default new wheels..gets confusing huh?
Greetings,
Just for fun I did some wheel shopping and read five (5) pages of posts. Interesting stuff and learned a lot about offsets and such.
This makes sense:
Offsets are simple. Lower offsets mean they are closer to the fenders. Example, +22 is closer to the fender than +40. Conversely, a higher offset numbers are closer to the suspension.
Now I'm an "old school" guy. I like a polished rim with a silver center. I found a couple I like on Tire Rack. With this page you can get a good look at the wheel and how it appears on the tC.
My concerns are as follows:
1) To get a polished lip wheel the offset becomes larger.
2) I would like the option of a TRD BBK open down the road. (this might not happen with aftermarket wheels however)
3) Would like to stay as close to factory spacing as possible. (no rubbing of tires against fenders or suspension.
Looks like sacrifices are inevitable going to aftermarket wheels. I like the following wheels.
Bremmer Kraft BR07
  • • Size: 18x8, 48mm Offset
  • • Price: $165 (each)
  • Est. Availability: In Stock
  • • Weight: 24.3lbs.
  • • Finish: Bright Sil w/Mach Lip
  • • Bolt Pattern: 5-114
  • • Construction: 1 Pc. Cast
Enkei Performance Lusso
  • • Size: 18x7.5, +42mm Offset
  • • Price: $180 (each)
  • • Weight: 20.7lbs.
  • • Finish: Hyper Silver w/Machined Lip
  • • Construction: 1 Pc. Gravity Cast
Chime in guys. Always open to comments.
tt
Old Dec 28, 2012 | 03:08 PM
KillerXtwo's Avatar
Have you taken a look at XXR wheels their 521's might be to your liking and should clear the BBK. they are not silver in the middle but have a polished lip and you can always paint the center
http://www.xxrwheels.com/xxr_521.shtml
Old Dec 28, 2012 | 03:09 PM
KillerXtwo's Avatar
i personally like the 522 and they will clear the BBK with no problem whatsoever
Old Dec 28, 2012 | 03:11 PM
KillerXtwo's Avatar
these are also cheaper than those two you suggested
http://www.nlmotoring.com/product-p/52188663.htm
Old Dec 28, 2012 | 03:18 PM
toytuff's Avatar
Thanks guys, I'll check them out.
These might fit the bill nicely. The offset is only one (1) mm closer to the fender so the TRD BBK should still fit down the road.
Enkei Performance EKM3
  • • Size: 18x7.5, +38mm Offset
  • • Price: $171 (each)
  • • Weight: 22.6lbs.
  • • Finish: Bright Satin Sil Paint
tt
Old Dec 28, 2012 | 08:00 PM
toytuff's Avatar
Perfect! Yeah, these work!
tt
GoodVibes
21
May 22, 2020 04:27 PM
Luisfc1972
Scion tC 1G Wheel & Tire
10
Oct 23, 2015 05:49 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
P944
Apr 30, 2015 06:04 PM
NewBox06
Feb 3, 2015 12:36 PM
