Tire sizes
I have a 2014 Scion tC. Tire spec is p225 45 R18. I'm having a hard time around my area finding that specific size tire. So my question is can I put on 235 50R18's on with no problems other than the speeding a bit off? I also have to pass inspection with them and don't wanna waste my money if it won't be passable.
*moved to correct forum by moderator
Hello Bubbasparx! Welcome to SL!
The 2015 Chart will be the Same for your 2014.
Yes, it will fit. But, you will have a -4.7% Speedo Error because of the bigger Diameter.
Also Check out the: tC 2G+ Wheel, Tire and Offset Calculator
Personally, I would not go that route. I recently had the replace a tire with the OEM size 225/45R18. That is the only size I would use.
It is pricey but, you find find one online and for less than your local tire dealers.
Your Choice.
MR_LUV
scionlife
371
Jun 2, 2015 11:00 PM
debris
Dec 16, 2003 11:50 PM
