Wheel/tire size help
Old Sep 10, 2011 | 05:49 PM
  #41
johndeo11's Avatar
that i dont know...
Old Sep 11, 2011 | 04:21 AM
  #42
oblivionlord's Avatar
Originally Posted by donsun
^there are people who care about performance more than looks.
@john deo, for slight reference to see what 17s look like on the tC2, check out fredric aasbo's formula-d tC2, it runs 17's i believe
Yea if that's the case then i wouldn't be using a Scion TC2. You want performance then get a real car you can mod, not a brand new gen econobox that has limited aftermarket options.
Old Sep 11, 2011 | 05:32 AM
  #43
Scrubtast1c's Avatar
got it mounted earlier today
i'll post more pics from the back tomorrow
and something i else got installed a few days ago
Old Sep 11, 2011 | 08:58 AM
  #44
johndeo11's Avatar
nice wheels... hope i can get mine next month... lolz
Old Sep 11, 2011 | 09:38 AM
  #45
thanks. looking forward to seeing the pics of your wheels when you get it
Old Sep 14, 2011 | 02:29 AM
  #46
Got a problem. The nut on the front wheels stick too far out n the center caps dont snap in. I lost 1 center cap already .. Neone know of a fix for this? I dont really mind which cap is on there as long as it covers the screw thing because its getting rusted
Old Sep 14, 2011 | 02:53 AM
  #47
jtk2's Avatar
cant wait to get my new wheels in.. had to get them custom. should be here around december.
Old Sep 14, 2011 | 12:29 PM
  #48
2tCornot2tC's Avatar
I had to make my own center caps for just that same reason...
I bought a set of TRD center caps and cut off all the “legs” off of the back side. Then I sanded it smooth – down to 400 grit.
I took off the Aluminum cover off of the F-Sport center cap (original), drilled a 1.75” hole through the center and sanded the outside face, again down to 400 grit to get a nice smooth finish.
This is what it looks like from the back…
This is what it looks like from the front…
Here is the final result…
Old Sep 15, 2011 | 06:07 AM
  #49
Any idea on how to do this for the center cap I have?
Old Sep 15, 2011 | 01:39 PM
  #50
While doing the brakes on my car, I friŠked up the right axle threads. I tried to un-stake the axle nut as per Toyota instructions and had a tough time undoing the nut. $500 later, I got new right axle…there is no need for such a long bolt hanging out. Per standard practices, all that is suggested is to have two threads past the nut. I’d get an 8” grinder with a cutoff blade and cut off the axle. That nut only holds the axle to the hub. The hub is held onto the suspension upright by the 4 bearing housing bolts on the wheel bearing. Those 4 wheel bearing housing bolts hold your wheel to the car. And, any threads beyond the nut is just added weight…but leave two threads per standard engineering practices.
The way I would do it, I would buy 2 each 7/8” washers and slide them over the axle to the nut. This will provide the natural stop for you…grind away.
Old Sep 15, 2011 | 07:27 PM
  #51
Blackedout011TC's Avatar
I agree 100% with 2t, cut em' down. Wheels look great btw. Thanks for sharing.
rain7905643
Mar 14, 2015 12:48 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
