Will 14 tC stock rim and tires accept spacers?
Old Aug 23, 2014 | 04:52 PM
MadcityTC's Avatar
Default Will 14 tC stock rim and tires accept spacers?
I was just curious if 2014 tC wheels can be flushed out with spacers?
Possible that it may need longer studs. Has anyone tried flushing out stock or have any information on it? I took a quick look for information but didn't see anything.
Old Aug 28, 2014 | 10:52 PM
biglilsteve's Avatar
Yup, plenty of folks have run spacers with OE tC2 wheels...myself included.
15mm spacer should flush you up nicely in the front. 25mm will do you pretty well in the rear. You need 5x114.3 bolt pattern with 60.1mm hub bore.
You can run bolt-on spacers, which are easily installed and removed...or you can run spacers that would require you to replace your wheel studs. I prefer the latter type of spacers that replace your studs...feels much safer than having an adapter separating the wheels from the hubs.
This is based on '11-'13 tC wheels, which should have the same size and offset as your '14+ wheels.
Old Aug 29, 2014 | 12:33 AM
MadcityTC's Avatar
Awesome thanks!
This was the exact information I was looking for...very helpful.
You wouldn't happen to have a link to where you got yours from, would you?
Old Apr 5, 2015 | 08:39 AM
stayintrucha's Avatar
I know this is an old post but any one recommend a brand?
Old Apr 5, 2015 | 11:46 AM
I recommend Eibach. And recommend to avoid Ichiba.
I you're shopping on Eibach's website looking for the part number, you can't select our car model...for some reason the spacers don't come up. Select another more popular car that has our same wheel specs. I used 2010 Lexus IS350. The exact spacers compatible with our car will come right up.
Old Jul 10, 2015 | 06:19 PM
jcraff3's Avatar
that is exactly what i am looking at doing 15front 25 rear because the way our car is. but i am now affiliated with isc and they havent made 25rear for the 60 bore yet. looking at getting wheels anyway so will run 15mm spacers in rear, nothing up front and work with my new wheels. thank's for replying to his post
Old Sep 30, 2015 | 09:22 PM
jcraff3's Avatar
they do i just put my isc spacers in the rear of my rs8. check them out! Teamgold Official - Home
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
eric_m
52
Jan 17, 2019 05:50 AM
Squishface
Sep 15, 2015 06:51 AM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
royder1976
Oct 6, 2003 07:41 PM
