Getting both filaments to light at same time
Old Apr 11, 2013 | 03:00 AM
hmc2261CT's Avatar
Default Getting both filaments to light at same time
So, I slammed my xa out, and now my headlights are not as effective, I already re adjusted them, but I noticed when just flashing my high beams, there is a point where you can be pulling the lever, and it will be in the middle of switching filaments. This results in both being in at the same time. Does anyone know how to modify the switch so that when I flip on my highs, it will still keep my low beams on?
Old Nov 9, 2013 | 07:26 PM
criminaltc's Avatar
Have you never played with wires before? This is very straight forward. Tap a wire from the low beams wire after its cracked on to the wire running the high beams after its cracked on. This will still only run the high beams after the they are cracked on, not all the time, otherwise if you just tap into the high beams with the low beams, the highs will always be on whenever you have the lows cracked on which is no bueno.
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
TheTripleC
Jan 4, 2015 06:46 PM
Scionic
39
Jul 20, 2004 02:46 AM
