2004-2006.5 [NCP61]
AC PROBLEM (noob needs help)
Old May 7, 2015 | 11:31 PM
ScionXa06's Avatar
Question AC PROBLEM (noob needs help)
I have the tools I just need help on what to do, I'm hoping its nothing to technical or expensive. I bought this car used, previous owner had installed a new "blower" for the A/C.
The recirculate air does not work, any idea as to how i can get it to work?
It's strange because when I am on the highway and my AC is in the OFF position, a lot of air comes out of the vents still, any ideas as to why? It sucks because if I'm behind a car or truck all of their exhaust makes its way into my car...so i have to switch the AC to blow only to the floor so that it doesn't hit me in the face. I REALLY want to get the recirculated air working.
There is also one other thing, temperature switch only goes this far.
It will not go to the right anymore than that. I have no idea why. It seems stuck and i don't want to force it all the way to the RED ZONE and end up breaking it...any ideas as to why this is happening? But I'm less concerned with this unless they two problems are somehow related.
Thank in advanced for any advice or help. I did some research and came across something called a "blend door" and "vacuum actuator" I have no clue if that's whats causing these problems.
Old May 8, 2015 | 11:42 PM
jct's Avatar
jct
you need a new cable for the temp control should cost you around 16 dollars from the dealer
Old May 14, 2015 | 09:34 PM
ScionXa06's Avatar
Thank you for the help. Can you tell me where it is located so that I can buy a new one a do it myself?
Old May 15, 2015 | 08:17 PM
jct's Avatar
jct
you need to pull the outter ***** off, remove the screws, remove the sliver trim pieces off the center area, remove said screws, unclip the wiring harness for the controls, remove the radio (for access purposes) if it's your first time doing this take your time look for hidden clips and such which they are in the open...
Old May 18, 2015 | 10:05 PM
ScionXa06's Avatar
Default seems easy enough
Thank you!
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
claiknx
May 17, 2015 11:44 PM
dchau55
Apr 17, 2015 11:33 PM
CPL_Radar
Mar 5, 2015 05:42 AM
