2004-2006.5 [NCP61]
OIL CHANGE HELP!!!
Old Dec 2, 2007 | 08:43 PM
Alex01's Avatar
Default OIL CHANGE HELP!!!
Hello,
I tried to change oil taday for the first time on my 2006 Scion xA, and i think i drained WRONG oil....
please see the pictures
1. i drained this plug (the oil was red color)
2. I think this is where i have to add oil, because when i take that thing out it shows there is no oil:
So, did i drain transmission fluid or differential one?
What type of oil should i buy and how much to add there?
Im waiting for replies!
Old Dec 2, 2007 | 09:13 PM
jct's Avatar
jct
yes you drained the tranny fluid i do believe your owners manual will state what kind of oil you'll need and how many quarts...
Old Dec 2, 2007 | 11:24 PM
Alex01's Avatar
ok, thanks.
So is this
the right drain plug for the engine oil?
I tried to open it, its very tight. In which direction schould i turn it???
Old Dec 2, 2007 | 11:56 PM
Jan06xB's Avatar
Well if you drained the tranny oil into a clean pan you could put it back in . . . but you probably didn't? So get to the dealer and get some more Tranny oil - I think you HAVE to use Toyota Tranny fluid. You should be able to fill through the dip stick.
Yeah that last post is the oil plug for the engine oil - counterclock wise just like any plug should unscrew - with wrench towards the front of the car push upwards - they usually get put on WAY TOO TIGHT and then stick.
zzbear
Apr 19, 2015 06:18 PM
voodoo2crue
Mar 18, 2015 01:30 AM
cid_mcdp
Jan 5, 2015 02:45 PM
scionman2003
19
Feb 26, 2004 02:55 AM
BlueBox
22
Nov 7, 2003 08:18 PM
