2004-2006.5 [NCP61]
Removing/replacing radio in 2005 xa
Old Apr 21, 2009 | 06:23 PM
KeithCary's Avatar
Default Removing/replacing radio in 2005 xa
I want to place the radio/cd player in my 2005 xA Scion. The cd player often won't eject a cd and I want an ipod-friendly unit in there, so I bought a Dual SDM6350 stereo. But, I can't figure out how to remove the stock radio. I've seen pictures on other sites of pulling off the heater ***** and I've done that and removed the screws underneath, but my radio (2005 model) is mounted above the heater and has separate trim pieces. Removing those screws doesn't seem to help me. Any ideas? (I'm an electronics tech and once I get in there should have no problem.)
Keith
Old Apr 22, 2009 | 03:14 AM
cobb's Avatar
If its like my 06, you remove the screws under the ***** for the hvac, then its a tug of war. The both ventsthe center piece around the radfio and the stuff between the ***** and radio, the inside/outside air vent, hazzard flasher and rear defroster.
Careful to not jerk the wires out and unplug those. The radio has 4 screws, 1 at each corner then it slides out forwards. You got like 3-4 connectors on the back with very short wires and need to do a reach around to unplug those.
PS, you are removing the side silver pieces and the screws behind those, right?
Old Apr 22, 2009 | 05:38 AM
KeithCary's Avatar
I'm not quite sure if the 06 is the same as the 05. Does anyone know? My radio has two silver pieces next to it and the hvac has separate silver trim pieces. I've seen pictures of some interiors where the silver pieces are continuous. Thanks for the info, in any case. I'll go out and investigate tomorrow. Keith
Old Apr 22, 2009 | 11:01 AM
jct's Avatar
jct
its the same as the 05, as the 06 is
Old Apr 22, 2009 | 01:53 PM
cobb's Avatar
The two longer silver pieces below teh radio pry out at the bottom and under those are more screws. Then its a tug of war.
Old Apr 22, 2009 | 02:45 PM
KeithCary's Avatar
Many thanks, I'll try it today. So the tug of war involves getting the longer silver trim pieces pulled out? OK, will try. Many thanks, Keith
NYCxB
Jul 10, 2015 03:17 AM
Kik
May 10, 2015 12:36 AM
vecchio
Apr 28, 2015 05:48 AM
vecchio
Apr 24, 2015 01:32 PM
minter66
Dec 15, 2014 01:45 PM
