06 xB - Rough idle - Out of ideas
Scanned the forums but did not find exactly what helps my situation unless I am not understanding. (Most likely!)
06 xB. 345k. 1st owner. Religiously maintained and driven conservatively. Last year the VSC and Trac Control came on. Pulled the plugs. All four worn to the nub. Replaced with Iridium NGK gapped at .032 Ran ok for the next year. Started idling rough last couple months. Pulled plugs
and they looked 'OK' but replaced with like for like and gapped at .035. Ran terrible and CEL lights lit up like Christmas. Gapped at .044 and reset ECU. Ran OK but then noticed after acceleration and if driven around 75mph for a couple miles when I came to a stop the idle was very rough.
Not getting CEL lights.
Possible coils? I bought some but tried the plug gap first. Now no so sure what to do. I don't want to try the coils if that isn't a possible solution because then I'm stuck with $100 in parts I cannot return.
I did get a P0302 code with the CEL lights. That's why I bought the coils but now my codes are clear.
If you can access a meter and cannot find the specs let me know but at 345K I would say replacing coil packs, especially if they haven't previously been replaced, isn't a bad idea anyway.
Replaced coil packs. Still idles rough. Now the VSC, Trac and check engine light are on again. Wow. I’m stumped. Going to re-gap the plugs from .044 to .032 and clean the throttle body. Hopefully that will help. Pretty sure I’m going to have to take her to a good Toyota shop and get a proper diagnosis done because I’m completely out of ideas.
Have you had the codes pulled again when the CEL came back on?
I can guarantee it isn't the gap of the plugs...lots of threads listing the dreaded VSC, Trac, CEL combo and seemingly lots of causes. Try cleaning the throttle body, as you already said you were going to do, and get a good electronics cleaner and clean off the MAF sensor also. Any smell of gas when you park the car...if so, I might start looking at the charcoal canister and the associated lines/hoses.
Last thing, and it's far more effort, might be a faulty cam position sensor or VVTI solenoid, both of which are a significantly more involved and expensive repair.
Threads for reference:
VSC, Trac and CEL Causes 1
VSC, Trac and CEL Causes 2
VSC, Trac and CEL Causes 3
Lots of reading and lots of causes and this one has always seemed to be a joy to troubleshoot and fix as so many things can cause it.
Goose5689
13
Jun 4, 2021 12:07 AM
Timmah
Nov 6, 2016 12:09 AM
Synthbent715
Jul 28, 2016 10:12 AM
mellybiscuit
20
Jan 27, 2012 06:59 AM
