1NZFE Won't turn over after swap, help please!
Old Oct 1, 2012 | 05:46 PM
HeavyD's Avatar
Default 1NZFE Won't turn over after swap, help please!
My xa blew the head gasket at over 170k last week so I decided to swap in a low mileage motor instead of doing a rebuild. After getting it into the car and ready to rock, it won't turn over.
The starter just clicks. We pulled the starter and it still spins it just won't spin the engine. It is the starter from my original engine and worked fin before the swap. We cleaned all the electrical connections and tried the ol 'smash on it with a hammer' technique but nothing is working. Any ideas on what the problem could be?
Old Oct 1, 2012 | 08:16 PM
Caprice0083's Avatar
Did you use any other parts from your previous engine? Also, check if you can manually turn the engine, put the car in neutral and turn it at the crankshaft bolt clockwise (someone check me on that). If you can't turn the engine then something mechanical may be busted.
You can also try following this guy's procedure.
VitaminE
Mar 24, 2015 03:36 PM
setpol
Feb 17, 2015 11:33 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
cid_mcdp
Jan 5, 2015 02:45 PM
ScionRo
Jan 2, 2015 07:54 PM
