2004 xB Manual..Clutch fluid Reservoir? Pedal adjustment? Nut size?
I have had to push my clutch down to the floor ever since I had the clutch etc replaced.
It's annoying and after a few years it's getting worse.
Like I need to push through the floor to get into the sweet spot.
I know you can adjust the pedal throw, but I can't seem to find the right sized wrench for the push rod nut.
Brakes are fine. I also wanted to check the fluid levels but can't figure out where the reservoir is.
I know it uses brake fluid but is it the same res too? How can I be sure it's getting to the cylinder?
Thanks
____
Thanks
____
This place has microfish pictures - perhaps that will help
OEM 2004 Scion XB Transmission (Manual) Parts Online | Toyota Parts Overstock
Parts 31477 & 31478 looks like a bleed nipple. If you bleed the air out of it, odds are it will work right
http://parts.lakelandtoyota.com/show...category=21655
Something the original mechanic should have done
Hi,
After I bleeding clutch slave cylinder and adjust clutch pedal high in spec. My clutch still does not has a good disengage and transmission shifting is not so smooth.
Should I buy the after market longer clutch pushrod to replace OE pushrod?
Thank you for advices.
Ericspyder
Ericspyder
Hi,
Ericspyder
Ericspyder
Ericspyder
Problem fixed..I replaced it with Redline 75W90. The shifting is smooth now.
Thank you for your advice to check the fluid level. I checked the level is fine.
But I realize the previous owner use regular GL5.
I replaced it with Redline 75W90. The shifting is smooth now. Problem fixed.
Ericspyder
____
Ericspyder
____
08xB714
07-12-2021 01:25 PM
IFeelYourPain
08-30-2017 02:16 PM
