clutch or slave cylinder???
Old Feb 10, 2011 | 07:44 PM
Blue_TC_Man's Avatar
Default clutch or slave cylinder???
ok so I was driving along, got hard to get into gear, then nothing. Wouldnt go into any gear. If I turn it off put it into gear and push the clutch pedal down it stalls like the clutch isnt engaging.
When I try to crank the car in gear with the clutch pedal down, it jumps like it wants to go.
Is there any way to see if it is the slave or master cylinder or the clutch itself?
clutch is a stage 4 Clutch masters about 1.5 years old
Old Feb 10, 2011 | 08:38 PM
helloninja's Avatar
Have you checked your brake fluid level? If it dropped and you got air in the line might not be able to disengage the clutch. Does the slave cylinder move when you push the pedal?
Old Feb 10, 2011 | 11:09 PM
Brake fluid I have not checked I'll check that and to see if the slave moves tomorrow
Old Feb 10, 2011 | 11:22 PM
Syldrin's Avatar
the clutch disc is gone thats what happened to my stock clutch.
Old Feb 11, 2011 | 04:37 AM
well the slave is good, brake fluid level is fine,
Im thinking it might be the throwout possibly, cause it just went, it wasnt a gradual or intermittent thing it went from working to not working
Old Feb 22, 2011 | 04:50 AM
J-List's Avatar
yep thats what happened to mines also.
steeze69
May 24, 2021 02:57 AM
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
