Old Aug 18, 2006 | 08:54 AM
yenzlife's Avatar
Default .
Old Aug 18, 2006 | 11:49 AM
ProshopXB's Avatar
Try an impact gun or a breaker bar on the bolt. Your also gonna have to find a way to stop the pulley from spinning when you try loosening the bolt. A little bit more elbow grease and strength and it should break free thou. Good luck...
Old Aug 19, 2006 | 01:10 AM
chadfo's Avatar
I used a rachet handle or something similar to go between spokes of the pulley and against a protrusion on the block to prevent the pulley from rotating. I think I also had to use an extension to the rachet to break the bolt loose. It is on there tight.
Old Aug 19, 2006 | 08:56 PM
metal112524's Avatar
ya i was lying on the ground pushing against a wall with your standard length socket it is a biatch but it will give... i had more problems with the alternator that the crack though due to the confined space and all just give it some mucle itll go. i had a socket extender between the bottom of the pulley right next to the block to stop the spining.
Old Aug 19, 2006 | 09:08 PM
yenzlife's Avatar
Thanx guys, im gonna try harder.....
Old Aug 22, 2006 | 01:47 AM
blown_xa's Avatar
an impact gun with good torque, that's the only way to loosen the bolt without the motor spinning, also don't loose the pulley pin!!! tiny pin that keeps the pulley from spinning on the crank
Old Aug 22, 2006 | 03:33 AM
pandaslayer's Avatar
I just used a ratchet, with a breaker bar, and put a big screw driver wedged in there to hold the pulley in place.
Also helps to tighten the bolt first, to break the seal of the factory loctite, then loosen it back up.
Old Aug 23, 2006 | 05:30 AM
yenzlife's Avatar
Thx 4 the help guys, i got my installed now, thx again
Old Aug 23, 2006 | 06:13 AM
lock tite... is that what that little puff of dust was when it finnally gave?
Old Aug 23, 2006 | 01:12 PM
that's the red crap you see on the threads
