adjustable cam pulley
Old Feb 25, 2007 | 03:42 PM
lukeracing's Avatar
Default adjustable cam pulley
where i can find a adjustable cam pulley for my 1nz?
or what model is compatible with this engine?
thanks
Old Feb 25, 2007 | 03:49 PM
dexter_5000's Avatar
there isn't one its a variable valve timing engine meaning the intake cam is adjusted via computer control.
Old Feb 25, 2007 | 06:36 PM
EVLTSTR's Avatar
Our cars are not Hondas... You don't want one.
Old Feb 25, 2007 | 06:40 PM
redwar1441's Avatar
why do you want one if you obviously dont even know what it does?
Old Feb 25, 2007 | 07:42 PM
lukeracing's Avatar
no, i reffer to the exhaust cam that is not variable...
Old Feb 25, 2007 | 07:49 PM
lukeracing's Avatar
HKS Adjustable Cam Gears
Full Aluminum, Exh Gear only for VVTi models - Engine
check this
http://www.hksusa.com/products/?id=629
Old Feb 25, 2007 | 08:06 PM
redwar1441's Avatar
those cam gears will not work on the 1nz-fe and for reason
.There are improvements that can be made to the FE engines- but the Toyota engineered power band should not be altered. The ECU program and Camshaft profiles, if changed will result in a loss of drivability and risk internal damage. You cannot do a better job than Toyota on coaxing power from these series engines, and needless to say, stay street-legal.
~toysport
leading toyota engine builder and racer.
www.toysport.com
Old Feb 25, 2007 | 08:11 PM
lukeracing's Avatar
OK, sorry
steeze69
May 24, 2021 02:57 AM
SloTC1
Aug 16, 2018 02:45 PM
MisterSkiz
Sep 27, 2015 10:25 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
Topfueltom69
Sep 6, 2015 05:25 PM
