A/C Condenser help....
Old Jun 6, 2006 | 10:31 PM
tlzook's Avatar
Default A/C Condenser help....
Shop is saying that I "holed" the A/C condenser and need a new one. Is there any cross reference parts from say a Echo or other Toyota that I might be able to score from a junkyard. Money is always tight and it looks like $200.00 for aftermarket and the stealership wants $500 plus install, total $875.00. I would rather bolt up something and then have the system purged and filled...gotta be cheaper...
Posted in Maintenance section but not getting any replies...Thanks...
Old Jun 7, 2006 | 07:13 AM
OldYeller's Avatar
Not under warranty?? what do you mean holed?? Here is a parts search site:
http://car-part.com/
good luck..............
Old Jun 8, 2006 | 02:12 PM
tlzook's Avatar
It's taken a shot from a rock or some object that put a hole in the front side. The dealership put some dye in it and that's how they discovered the leak...I would love
to blame someone but it went out last fall and I took it in for a check and to fix a couple of things before the warranty was up....I have almost 40K on the ODO and not quite 2 years old...
Old Apr 13, 2007 | 01:35 AM
Aery's Avatar
I have the same problem with my Scion. What BS. You'd think Toyota could do a bit better to prevent this sort of thing.
Old Apr 13, 2007 | 01:41 AM
jct's Avatar
jct
you would need to buy a new A/C drier also
Old Apr 18, 2007 | 02:51 AM
cobb's Avatar
Have you tried a sealer kit? Advance auto sells one that contains metal flakes and seal sealer to put in a system for holes in evaporators or condensors. I used it in my 240d and it fixed the leak. Its like q2 bucks and sold by I believe artic. Their freon isnt bad either and they ahve a new one that NASA helped design to make it cooler faster.
The alternative would be to get someone to braze it who has torch skills.
sabot7726
Apr 28, 2016 08:20 AM
Jus2tastee
Oct 1, 2015 08:57 PM
BlingSlade
Sep 5, 2015 08:52 AM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
