Are C5x Transmission gears interchangeable?
I am going to be rebuilding the C50 in my xB. I would like to replace the final gear set and the 5th gear set.
I know 5th gear from a Corolla can be swapped. But can the final drive set be swapped?
Are all the C5x transmission gears interchangeable?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; 07-28-2020 at 03:21 PM. Reason: Moved to Correct Forum by Administrator
I can't speak to the interchangeability, but I've come across a few things in recent months that may be useful to you. The first is a website for someone that appears to specialize in transmissions for the Lotus and MR2. It may be worth reaching out with questions.
WC Engineering : Service Work
The second is a video by someone that races a Yaris and appears to have done some very impressive gearing swaps. Here he discusses compatibility a little:
Please note that I have no affiliation with either of these individuals; I just thought you might find it helpful.
You can get the 6th gear set from a C60 check out
https://www.armstrongfamilyblog.com/...-c60-tear-down
https://www.armstrongfamilyblog.com/apps/search?q=c60
PTUNING
59
01-03-2014 01:02 PM
