CB Radio and PO351 code
Old Jun 20, 2008 | 07:38 PM
kzhorse's Avatar
Strictly Scionized
Default CB Radio and PO351 code
Well it has been about 4 years without talking on the radio,So I decided it was about time to bite the bullet and install a radio in the "B" the radio and antenna went fine no problems good match.
But when I throw the amp in line as soon as I key up It throws a code for Ignitioncoil #1 primary circuit fault would this be just RF overload or a sign of a coil going bad?
Or would the sudden voltage drop cause it?
Scott
Old Jun 22, 2008 | 10:34 PM
jct's Avatar
jct
bad ground maybe?
Old Jun 23, 2008 | 07:17 PM
Winter's Avatar
P0351 is one of the ignition coils, coil A primary/secondary to be specific.
Old Jun 23, 2008 | 08:13 PM
kzhorse's Avatar
Strictly Scionized
Yea I know what the code was(Posted in my first post) Just trying to figure if it is RF related or just under voltage.
Scott
Old Jun 24, 2008 | 10:09 PM
Winter's Avatar
bah, my bad, i over looked that. i doubt it would interfere with the ignition system... it's just a CB... it's just like having a second stereo basically in my opinion.
Old Jul 2, 2008 | 11:48 PM
kzhorse's Avatar
Strictly Scionized
Well it wound up being a power issue not a RF one.
Replaced the battery with a 1000 cca and all is good for now,Looking for a small 100+ alternator to run a seperate charging system but this will work for now.
Scott
Old Jul 3, 2008 | 11:09 AM
jct's Avatar
jct
wow now thats an antenna!!!
Old Jul 3, 2008 | 06:12 PM
Winter's Avatar
you could always get a soft antenna or just a few wires and run them through your headliner around the edges like the stereo's antenna is routed so you don't have this huge tower on the top of your xB.
Stinger makes some nice alternators but you'll have to call them and do a custom order to your liking. there's also another option for an Iraggi alternator, this guy rebuilds the stock alternators to produce alot more power without sacrificing reliability *not like stinger's alternators are bad or anything but anyway...*. not sure if he's here on SL, but i'll PM his email to you if you want to go that route. he has two models for the xB, one that is 115amp idle and 180amp max for about $380 and another that is 130amp idle and 200amp max for about $400.
Old Jul 3, 2008 | 09:49 PM
kzhorse's Avatar
Strictly Scionized
Sorry but a piece of wire ran around the headliner wont work for what I want.
I'll keep my little antenna.
jct
Jun 10, 2015 08:32 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
crocker
Dec 2, 2014 03:44 AM
