Coolant?
Old Apr 2, 2019 | 06:00 PM
GeoffScion's Avatar
Default Coolant?
xA 2006 Coolant any particular brands?
Going to Pep Boys want them to flush and refill w/ proper brand/ grade.
______________________________
Last edited by MR_LUV; Apr 2, 2019 at 08:58 PM. Reason: Moved to Correct Forum by Administrator
Old Apr 3, 2019 | 08:35 PM
MileHightC's Avatar
Super Moderator
SuperMod
A quick search would have told you that Toyota is typically the preferred coolant but Zerex also makes an 'Asian' coolant that meets the specs of most Asian automakers and is what I am running.
You can tell Pep Boys to flush and fill with whatever you want but I am guessing they are going to use some 'generic' coolant that they likely use in every vehicle.
Old May 14, 2019 | 07:07 AM
adorable's Avatar
https://www.ccjdigital.com/understanding-coolants/
https://www.cgj.com/2013/05/20/what-...an-i-mix-them/
https://parts.olathetoyota.com/blog/...t-color-guide/
Honestly, smarter to make sure you use Toyota coolant, else, the correct type of coolant matching what you have in your car. That'll require someone to look up the right coolant for the brand selected. (It's a little complicated ,)
Spencertimm
Aug 27, 2018 04:48 PM
randomsuper
Jun 22, 2011 10:28 PM
zapco23
Dec 1, 2010 02:51 PM
kronicillusionz
Mar 5, 2007 11:25 PM
noTCed
Oct 28, 2006 04:03 AM
