Electric fan not working..
Old Aug 26, 2011 | 11:04 PM
hardlucktattoo's Avatar
Originally Posted by Reactor
Here:
should i check the blower resistor too??
Old Aug 26, 2011 | 11:16 PM
Reactor's Avatar
What's the problem with the blower?
Old Aug 26, 2011 | 11:23 PM
nothing just didnt know if it had anything to do with it..i got a test light today when i get off of work tonight ill check that fan resistor and post back what i found thanks again for helpn me out
Old Aug 27, 2011 | 01:04 AM
Reactor's Avatar
Here is the radiator fan diagram: http://scionlife.org/Scion_Docs/2004...adCondFans.pdf
If the fan comes on with no problems when you turn on the A/C but never comes on when the engine starts to overheat, then the only 2 things that can cause that are bad contacts inside Relay #2 or bad fan resistor. Assuming all the wires are connected and intact.
It's possible to have bad ECU or Temp sensor but that rarely happens and would normally turn on the Check Engine Light on.
Make sure the coolant level is OK inside the system, not just reservoir.
Old Aug 27, 2011 | 01:12 AM
All fulids are good when I unplugged the #2 fan relay the ac fan won't turn so I thought it was the #1 fan relay that does the coolant I unplugged that and used the horn relay that's the same as #1 4 prong and the #2 relay is a 6 prong
Old Aug 27, 2011 | 01:59 AM
Reactor's Avatar
Just probe the socket for the Relay#2 with the test light. If you have ground at terminal #4 then the fan resistor must be OK.
Old Aug 27, 2011 | 02:32 AM
I unpluggeg the fan resistor and with a test light I get nothing in the relays #1 and 2 I get 2 lights on with test but no power to fan resistor????? Relays look good
Old Aug 27, 2011 | 02:44 AM
Can you rexplain in new to this
Old Aug 27, 2011 | 02:47 AM
Ok just unpluged the coolant temp senor and the fan kicked on does that mean the senors is bad?
Reactor's Avatar
Can you just do what i suggested in post #26? You are not looking for power- you need to see ground. That means the alligator clip on the test light needs to be on the positive battery terminal and once you touch #4 pin on the socket for the relay #2 with the test light's tip the light should come on.
Old Aug 27, 2011 | 02:57 AM
We are also getting a ground on #1 from the top too? But we unpluged the temp sensor and the fan kicked on we replugged the temp sensor and the fan stop now I got trac and engine lights on
Old Aug 27, 2011 | 03:05 AM
Reactor's Avatar
I don't think so. #1 terminal will have power from the fuse- not ground. All pins on the relay are marked with numbers. Make sure you are referencing them to their correct terminals on the relay's socket.
Old Aug 27, 2011 | 03:10 AM
Ok we got ground on 4,3,2 on rely #2
Old Aug 27, 2011 | 03:26 AM
Reactor's Avatar
Then i don't think you have electrical problem. If you disconnected the temp sensor and the fan kicked in- that's how it's supposed to work. Are you sure your car actually overheats? The cap may be bad so the coolant may be coming out because of that. If you hold RPM at about 2K for few minutes i think the fan will be on.
Old Aug 27, 2011 | 03:53 AM
Well the top 2 raditor hoses leak after about 10 to 15 mins of stand still and the fan never kicks on plus now that I replugged the temp sensor in I got light trac and engine...
Old Aug 27, 2011 | 04:05 AM
Reactor's Avatar
IDK, since you probably have no way of testing the sensor may be just replace it and see what happens.
Old Aug 27, 2011 | 04:10 AM
Ok cool we used the test light to check the wire on the end of the temp sensor and there's nothing and now that I'm gettn engine light it must be it ill try to repace it sunday and ill post and I really thank you for your help reactor I'm just new to the xb and just got it making sure its cool before I drive it I don't need to replace the motor lol
Old Aug 27, 2011 | 04:17 AM
Reactor's Avatar
Sensor gets only 5 Volts from ECU when the key is on, so that's not something you would check with the test light that needs 12 Volts.
You can disconnect battery for few minutes to turn off the warning lights on the dash.
Old Aug 27, 2011 | 04:20 AM
So whit everything we talked about what would you say the problem is?
Old Aug 27, 2011 | 05:05 PM
Reactor's Avatar
Without knowing the engine temperature i can't make any guesses. But your hose clamps are loose. Hoses shouldn't leak no matter what.
