Electric fan not working..
Old Aug 27, 2011 | 06:27 PM
  #41
hardlucktattoo's Avatar
Originally Posted by Reactor
Without knowing the engine temperature i can't make any guesses. But your hose clamps are loose. Hoses shouldn't leak no matter what.
I got them as tight as you can get them but water is still forcing out the top 2 hoses
Old Aug 27, 2011 | 07:36 PM
  #42
Reactor's Avatar
Clean up the fittings or replace the hoses.
Old Aug 27, 2011 | 08:24 PM
  #43
All new racing hoses on it
Old Aug 27, 2011 | 11:30 PM
  #44
Reactor's Avatar
Radiator cap is supposed to hold about 16lbs of pressure in the cooling system. Then it opens and releases coolant into reservoir. If you have coolant leaking past the clamps before that, then you need to fix them. It doesn't matter if the engine has a blown head gasket or whatever. Clamps and hoses have to hold up and not leak even if the radiator is ready to burst.
Old Aug 27, 2011 | 11:44 PM
  #45
Roller_Toaster's Avatar
Do xb1's have the fuse block that includes fan's like the xb2's do? I had to replace my fuse block (5 fuses in one....awesome Idea toyota) for around $50 from the stealership.
Old Aug 28, 2011 | 12:56 AM
  #46
ajcadoo's Avatar
If you are desperate, plug in an OBDII tool (Kiwi Wi-Fi or UltraGauge). Find the "Engine Temp Gauge" and turn on your engine. At 205 degrees F, the electric fan is supposed to turn on. I suggest getting an Ultragauge just cuz its cheaper and it actually helps you out with a bunch of different gauges too. It was well worth the money I spent.
That should help you determine if it truly is a fan problem or something else.
Old Aug 28, 2011 | 01:17 AM
  #47
All fuses and relays are good even the fan sensisor so its got to be it when I unplugged it. It started to run
Old Aug 28, 2011 | 07:11 PM
  #48
JD Huyler's Avatar
My fan seems to be coming on more. Maybe it's just me. I mean it always came on in drive thrus after about 2 minutes sitting idle, and would come on for 20 seconds before coming back on in between 2 minute intervals. It seems to come on more now when going slow like 10 mph over a road with speed bumps. Probably just me, and finding something to worry about. Coolant is full. Damn the XB for no temperature gauge though!
Old Aug 30, 2011 | 05:18 PM
  #49
Put the new temp sensor in and fan still didn't come on I drove it for about a hour and then let it sit still no fan
Old Aug 30, 2011 | 06:21 PM
  #50
Reactor's Avatar
As long as it's not overheating i don't see a problem with that.
Old Aug 30, 2011 | 06:29 PM
  #51
The only other thing I can see is when you frist start it for
About 5 mins the temp light comes on in the dash then cuts off
Old Aug 30, 2011 | 07:24 PM
  #52
Reactor's Avatar
That's how the blue Low Temp light supposed to work.
Old Aug 30, 2011 | 08:56 PM
  #53
JD Huyler's Avatar
I went for a ride a week ago, and it was real rainy, and my friend was putting on the defrost cause the windows were getting fogged up. Realized the control was turned to the defrost position. That might be why my fan kept kicking on!
Old Aug 30, 2011 | 09:05 PM
  #54
Found this behinf passenger side front wheel just hanging does anyone know what it is its hot I put test light on it
Old Aug 31, 2011 | 05:55 PM
  #55
Reactor's Avatar
May be the sidemarker wiring?
Old Sep 3, 2011 | 04:12 AM
  #56
frogbox's Avatar
looks like the connector that should be plugged into the AC line near the dryer, located near the sight glass window
Old Sep 3, 2011 | 05:22 AM
  #57
I don't know where it goes I think its for the fog lights where I put hids....still no fan when gets up to temp
Old Sep 3, 2011 | 06:21 PM
  #58
Reactor's Avatar
What are the colors of the wires going into the mystery connector? It will be super easy to find out what they are for.
Old Sep 3, 2011 | 06:26 PM
  #59
one is white one is green
Old Sep 3, 2011 | 06:44 PM
  #60
Reactor's Avatar
Should be the sidemarker light on the fender then.
