Engine swap..Help!
Engine swap..Help!
HELP...
I have an 08-06 car, body wrecked engine ran great till wrecked. Got an 05-05 good body, blown motor. Motor looks like connecting rod @ cyl #4 broke and put hole in block both sides, amazingly engine still cranked. On 05-05 engine cyl #1, #2, #3 about 60lbs compression cyl #4 0 compression.
I took 08-06 engine, tranny (both manuals) and 1/2 shafts complete as one piece from the 08-06 car and put in 05-05 car. Used 05-05 wiring harness and computer. All connections were the same but two. The knock sensor and the water temp sensor. Took those two off the 05-05 motor and put
on 08-06 motor fit right in and all electrical plugs fit just right. Started car and ran rough checked core got miss fire cyl #3 and #4. took coil pack plugs of both #3, #4 no change in how engine ran. Took of #2 and then #1 car wanted to die both times.
Note with every different attempt cleared code reader. So I switched coil packs and plugs a few time, with the same result miss fire #3, #4.
Got a wiring diagram of the ignition to verify coil pack wire connection and how they ran.
Checked all coil pack wires for continuity, 4-wires from coil packs all have a yellow, whit/black and black/red
(that interconnect to each other in the wiring diagram) all had correct continuity. then there are the wires that come from coil pack to computer, green/red, green/orange, green/black, green/yellow.
Tested all those for wire continuity to plug that goes into computer. All those wires are good.
Only thing I can think of left is bad computer. When the engine has a catastrophic failure like a broken rod that puts holes in the block from cyl #4 could that mess up the computer to turn those two cyl off.
Car was with out a battery for min of several months so I though computer would reset with no power for that long.
Any ideas?
Thanks
____
Any ideas?
Thanks
____
I get the same Codes:
P0300
P0303
P0304
Since the 08-06 motor was running I have not done a compression check. Will do this weekend.
Really don't think it is compression but I can check it off the "What If" list.
_____
P0300
P0303
P0304
_____
Engine swap
hello all. here is an update.
please refer to main post for issue and work completed.
I have done a compression check all cylinders around 130psi, when i took plugs out of cylinders #3, #4 (the two that have the misfire code and appear not to fire), both plugs were coated with gasoline, so i know the injector are working as i am getting fuel in cylinder. I also checked to make sure that the timing gears on crank and cam are same part number for both the 05-05 engine and the 08-06 engine and they are.
So quick recap.
took running motor from an 08-06 car and put in an 05-05 car. used computer, engine wiring harness from 05-05. Now have 05-05 car (using 05-05 computer and wiring harness) with 08-06 motor car starts only runs on #1,#2 cylinders. have swapped coils, plugs, verified wiring has continuity, #3, #4 gets fuel and no change in timing gears between the engines, got good compression. no matter what i do only #1, #2 work #3, #4 nothing. besides new computer any other ideas of why #3, #4 will not work?
thanks
So quick recap.
thanks
miata
01-24-2023 08:43 AM
etsnet
13
10-19-2009 02:19 PM
david90
46
07-26-2007 12:28 AM
