Exhaust
Exhaust
OK i bought a OBX exhaust about a month ago and went in easy enough but i replaced the donut gasket that goes between manifold and cat pipe twice first one was a larger one then this one was a oem replacement, I keep getting a cel and when i run the code says that there is a leak I am assuming it is at this point cause no issues before install looking at getting headers to go with the kit to complete it all but til then I would be nice if I can get the cel cleared for good. Any Ideas?
did you clear the code after you replaced the donut?
I assume that you replaced the donut because of the fault code
I'm pretty sure if the fault code wasnt cleared that it would still be there???
there are 2 o2 sensors in the xB I believe
be sure to check them both
I found this
"I found out how to bench test an o2 sensor and PCH is right (which now makes sense). The header o2 sensor is faulty. I checked them both anyhow. Using a digital 12vdc meter, you can read between the housing (neg) and the lead to the computer, should get 0 to 1.1 volt. Then heat up the tip with a torch and watch the voltage change to about 6 volts. Again, let it cool and it should drop. I searched "Oxygen sensors how they work" and got a wealth of useful information. I will let you know when the part comes in. And, the cel eliminator "
the o2 sensor will make voltage as it heats up..
I found this
Has this been resolved? If yes, how? I just got the OBX catback installed and my box is throwing a P0420 code (cat converter below threshold). I'm thinking of getting a mechanical O2 fix just like this one: Megan Racing Mechanical CEL Fix. I know Weapon-r also makes one but by the size of it the Megan one would make a better fit. Then I also saw this: OBD II 2 O2 sensor simulator at E-bay which sends a signal to trick the OBD.
I don't mean to thread-jack but this may turn out to be a solution to the original post too. Your 2 cents will be appreciated.
Originally Posted by mravetto
No I have not resolved the issue yet, I got the same code. I was thinking of trying a new 02 sensor but out of funds for now sorry i was not of any help, if either one of those work out for you please let me know.
carid
02-09-2015 01:49 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
