Help! 2005 Scion xB..Bolt that holds in the Camshaft Position Sensor..
Hi all,
I would really appreciate some help, if possible. I have checked with Toyota, for the record, and received no response, and it's been awhile (a week now).
I just need the Specs or Part Number for the Bolt that holds in the Camshaft Position Sensor (on the right of block, near air filter housing, so many different names for the part) .
Does anyone here have any ideas? I'm desperate at this point.
Thank you!
Sticky How To Advanced Search SL (Scion Life)
______________________________
Thank you!
Last edited by MR_LUV; May 8, 2020 at 02:21 AM. Reason: Moved to Correct Forum by Administrator
A good place to look up the part numbers is https://partsouq.com/
I looked up the part number and it seems to be 91551-80614, I may be wrong but you can check it out.
Hope this helps.
Hope this helps.
codycat
May 4, 2005 07:03 PM
