How to increase my xB's Gas Mileage?
deffinitley even thinkgeek.com has them check it http://www.thinkgeek.com/gadgets/electronic/8426/
its practical and it can match my stereo color.
Originally Posted by Supertech
just a little FYI, the max pressure on the tire is put there by the tire manufacturer. that tire was not made specifically for a scion and can be mounted on literally thousands of vehicles with different weight/load ratings. That being said, i have personally mounted sets of tires that required extreme pressure to seat the bead. They took almost 100 psi to seat the bead and we actually placed them outside our shop door just incase the thing came apart.
Originally Posted by brijoeall
Thanks for the post for the scangauge. Pretty cool tool. Do you have to remove it for emissions check & service dealer work?
I drive an even combo of city and highway (20mi to and from work 5 days a week, 40mi to and from weekend job twice a month), and I've kept a spreadsheet for over 40 tanks of gas. Average is 32 MPG over the last 23 tanks.
2005 xB CM Auto, YDR short-ram intake with K&N filter, OBX iridium spark plugs, 31-33 psi in the tires, Michoku's DIY groundwire kit.
Originally Posted by mushroomdreamer
when changing your air filter to an k&n you will lose. increased horsepower causes loss of fuel.
Also, max tire pressure listed is for maximum gross weight on said tire. The door listing of tire pressure is an engineers number based on a specific tire on a specific car at a specific weight. That weight is not usually maximum gross weight. Under inflation is a bit worse because it causes excessive heat build up. I just rented a Toyota minivan and drove to FL from PA. I put the rear tire pressure at max as listed on the sidewall. I averaged 87 MPH the whole trip and got 25-27MPG!!
Also, over inflation will tend to increase traction to a point and then a decrease if too high. I would personally run 2 pounds over in front and 4 pounds over in rear.
My K&N filter has added to mpg. I have a ScanGauge and trained myself to drive for mpg. After I added the filter I drove the same but have so far seen at least 2 mpg improvement. Since it is winter and I live in an urban area, each trip is a bit different because of temp and warmup time and length of trip, but there is a definite difference.
IMO efficiency gets added horsepower which can either be used to go faster or save on gas. Next up spark plugs.
My second choice car was the Honda Civic Hybrid but it is too small for kids and gear. So I am trying to get similar mileage w/ the roomier cheaper xB. Hauled a 4x4 piece of plywood in the back last week.
The only issue with K&N or ANY other filter that "increases horsepower" by letting more air through the filter media is that the 1-3 possible HP (or 2-5 MPG) increase comes at a cost of less air filtration. That equals more engine damaging particles floating around your crankcase.
http://www.bobistheoilguy.com/airfilter/airtest3.htm
OEM filters are quite good actually.
Originally Posted by hotbox05
not true. most of the performance filters do filter worse . but a good handful or so filter better while gaining power.
The one I posted clearly shows Amsoil and K&N vs. a standard paper filter. Neither filter as good as paper.
Are they that hard to find?? Ha…does not surprise me at all.
Just to clarify. I do not doubt the give a tiny increase to HP and gas milage, I simply debate if the excess dirt and potential engine (and MAF) damage is worth those gains.
man thats crazy i dont know how you people get 30 mpg + . im very light footed on the gas and keep my tire pressure at 37psi , i get all the work done by the toyota dealer and i have never gotten 28mpg i average about 26.5mpg but then again i drive in traffic about 85% of the time oh well - i need to get my suzuki 650dr , my buddy tells me he gets about 58mpg
the only time i really noticed a difference in my mileage was when i had to do lots of little small trips (ie stop, park the car and go multiple times). i got maybe about 26mpg then.
most of the time i'm driving 30 miles a day on the freeway, w/ some slow traffic and i've been getting 32mpg in the winter and about 35 at other times w/ minimal use of the ac - it just robs too much power
i'm usually by myself, no extra load, running mobil1, k&n, and don't drive aggressively most of the time. i have a stick shift
