HoW MuCh NOS???
Originally Posted by eeyoredragon
No, NOS is an acronym for Nitrous Oxide Systems, and also an acronym used for New - Old - Stock when referring to parts.
NOS is not a gas, Nitrous is a gas. (n2o)
Lets put it this way, the people that don't understand n2o or nitrous, but understand NOS aren't the people you want telling you what's safe to spray.
Anyhow, with a wet kit he shouldn't be able to stray from stoich... it SHOULD add fuel correctly, if it doesn't it might as well be in the trash.
woooo keep quoting!
woooo keep quoting!
WOOO AND AGAIN!!11
woooo keep quoting!
WOOO AND AGAIN!!11
Better make it 2, because you topped at out at 140 today...
Say goodbye to your aluminum floor pans, when your laptop starts saying WARNING! dont close it!!! The floor will fall out right after that!!!
It's going to take more than that crotch rocket...
OH SH*T NAWZ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
**insert dramatic cinematic exaggerated explosion**
You can have any beer you want, as long as its a Corona.
Remember the buster didn't run back to the fort.
well, wouldn't it make sense to tune everything correctly anyway, as spark retard works against the whole point in putting nitrous in in the first place?
i guess ill be the one to answer his question more directly...i ran the xb with a 75 hp wet shot. it was running fine at the track. but then one day i was squeezing with a few poeple in the car...and when i got to the parking lot...my car was not idling well. i changed my plugs thinking that they may have been burned out. but that is not it. i think there is somethin wrong with the timing. and the car is still sitting at home in the garage while im away in college.
SO...dont run a 75 shot without proper tuning. if you were to do it...get a safc. i forget who wrote it...but he is right...the ecu can only correct what the nitrous is doing so much. so stay with a 50 to be safe.
p.s. if anyone knows whats wrong with my car...let me know
woooo keep quoting!
WOOO AND AGAIN!!11
BTW most ECU's will correct for about 10% +/- factory original timing/fuel/air curves. but their are many piggyback computers to help with that...
Just out of curiocity have you done a compression test yet? or leakdown? and i would hope to god that anyone in their correct mind woul;d order a kit and start off small and work their way up before you went all ___ hat with it.
There is no such thing as a gas called NOS. It's nitrous, or n2o - NOS is a company, Nitrous Oxide Systems.
So, in closing nitrous and n2o are acceptable terms... this isn't F&F here, we aren't in fantasy land.
I just got soo tired trying to "educate" F-n-Fers about it. It was a losing battle.
How many people do you hear talk about "in line skates" as "in line skates"........they all call em Rollerblades. It's a common thing........a brand that popularizes a product often becomes synonymous with the product. So I don't think it's appropriate to flame someone for using the term "nos" to refer to nitrous. I personally don't like the term.....but I won't be on someone's ___ for using it interchangeably with nitrous.
KiL
KiL
Sarcasm, sorry. AFC's aren't really all that great, they modify what the ECU THINKS is the true MAF signal, by doing this it tricks the ECU into adding more/less fuel. BUT!!! Changing MAF signals can affect timing, negatively!!!
Please don't ever tell anyone to get an AFC... Sarcasm, sorry. AFC's aren't really all that great, they modify what the ECU THINKS is the true MAF signal, by doing this it tricks the ECU into adding more/less fuel. BUT!!! Changing MAF signals can affect timing, negatively!!!
A full engine management system would in the end be less costly the a few piggybacks. maybe you should look at a Haltech system for your needs.
Never do more then 50% of the stock engine power with out the engine being built. This means a 35 shot or 50 shot. Put in a throttle switch and O2 Cut off. This way only kicks in when turned on and at full throttle and when the o2 sensors sense that the A/F is more the 14.5 either way (lean or rich) it will shut it off. Keep in mind the xB and xA have returnless fuel lines. This makes it a lil differnt then some other cars. Might also want to ungrade the fuel rail to handle the extra fuel. Wet is the the only way besides a direct port for the scions. A dry kit wouldnt work very effectively.
$.02
$.02
aarontrini85
37
Jan 24, 2009 03:21 AM
samhain
Jan 8, 2007 02:44 AM
MattJtC
Jun 25, 2006 07:14 PM
TheScionChef
9
Nov 6, 2005 02:48 AM
