Injen Cold Air
I've ordered my Injen cold air intake for my XB and I am wondering how tough the install is going to be. Any special tips that I need to know or hints that would help me get it done quicker? Or is it going to be a total pain? Any help is appreciated.
its not that bad. folowthe instructions but there are some blank spots that lose some detail. you will first have transfer the MAF sensor to the Injen pc. i would suggest undoing the Pos+ terminal. then put the extension pc in. you dont have to remove the battery but there is a small wire harness thats clipeed on top of what is called the shotgun. its under the battery and the headlight and its the flat metal pc. you will have to remove this clip. snake your C/A/ extension down and under the dr. side light assembly. you will also have to remove the 4 10mm nuts on the engine cover and remove it. once you have that off and the C/A/Extension in then you can fanagle the pc that connects to the T/B. of course this is assuming you've removed all the factory equipment. the instruction will guide you thru most of it quite easily. i did find the filter easier to put in from the bottom with very little effort.
hampton1100
May 28, 2015 07:32 AM
carid
Mar 30, 2015 07:08 AM
arinvolvo
Jan 21, 2004 11:40 PM
Hardhitten
22
Nov 13, 2003 11:53 PM
