just installed an echo ecu...
Old May 20, 2008 | 03:24 PM
EasysBox's Avatar
Default just installed an echo ecu...
this is my first post in quite a while. i kinda fell off the grid, had a lot goin on, moved up to bremerton, yeah, anyways, i just got an ecu out of an 05 echo with a manual tranny, plugged right in. i drove it around the block really quick to make sure it ran fine and so far no problems. i haven't had time yet to really see what the difference is, if any, but i will keep adding to this thread, i will be playing with it today...
Old May 20, 2008 | 08:09 PM
Black_Sheep_xB's Avatar
you da man!
Old May 20, 2008 | 08:25 PM
EasysBox's Avatar
yeah, and it feels like it is going to run a lot better, if i can only figure out my electrical problem...
Old May 20, 2008 | 09:41 PM
Iateacricket's Avatar
Interesting......
Old May 20, 2008 | 10:01 PM
EasysBox's Avatar
btw... i picked the ecu up off of ebay for $60 shipped...
Old May 20, 2008 | 10:42 PM
EasysBox's Avatar
solved it, bad ground by the headlight, cleaned it up and now its running great. will post updates on differences with echo ecu...
Old May 20, 2008 | 11:45 PM
BlueJDMBoxV2's Avatar
sweet i will be watching this.
be cool if you could do a dyno of before and after to se if you have any HP gains or anything like that.
Old May 21, 2008 | 12:26 AM
EasysBox's Avatar
i just moved to the area and have no idea what is around here shop wise, anyways, i am not really anticipating any "gains" in power, just consistancy... but we will see...
Old May 21, 2008 | 01:00 AM
greybox's Avatar
Maybe I missed something but what would a stock echo ECU do? I have heard they are easier to use with a turbo or s/c because they have 1/4 the memory the xB one does-or is this just a "to see" kind of thing because no one knows what will happen?
No disrespect, just asking.
Old May 21, 2008 | 01:08 AM
EasysBox's Avatar
its not a learning ecu, it is just a 16bit as opposed to the xbs learning 64bit, so it wont fight the piggyback...
Old May 21, 2008 | 01:26 AM
Boxer_Rebellion's Avatar
Ahhh, interesting...
Old May 21, 2008 | 02:30 AM
hotbox05's Avatar
only benefit to an echo ecu is that it is NOT a learning ecu so it can work better with forced induction and tuning
Old May 23, 2008 | 11:43 PM
jdlong's Avatar
definitely watching this. don't fall off the face of the earth again until you update us. i'm willing to do this to if it all works out for you.
is the pinout the same? (ie: plug and play?) and have you scanned for any codes? i'm assuming it keeps the odbII.
Old May 23, 2008 | 11:56 PM
Big_Bird's Avatar
*watching*
would like to see how this goes.
Old May 24, 2008 | 12:22 AM
EasysBox's Avatar
so far it is going good, runs great, nice and consistent... will keep posting as miles rack up...
Old May 25, 2008 | 01:24 PM
itsme's Avatar
find a spot to do a lil ebrake sliding to see if you still got stability control (there should be a beeping if you do).....do a burn out to c if you have traction control (if it doesnt burnout and you have to turn off the traction control by pressing the switch you still have it)
Old May 25, 2008 | 03:29 PM
EasysBox's Avatar
i dont have it, the lights are on... not that i ever used it anyways ;)
Old May 26, 2008 | 01:43 AM
itsme's Avatar
do you still have abs?
Old May 26, 2008 | 02:04 AM
EasysBox's Avatar
havent tried that one yet, though the light isnt on, when i get a chance to i will try it out, it will prolly rain again in the next few days... the only things that i know i dont have is trac, vsc, and ac...
Old May 26, 2008 | 02:48 AM
draxcaliber's Avatar
so you don't have abs, vsc or trac. but it is not a learning ecu, so you can tune it all you want with a piggyback.
