Knock Sensor swap..
Old Jun 9, 2020 | 01:54 PM
rdjette's Avatar
Default Knock Sensor swap..
Motor swap. I have an engine 08/06 manufacture date, knock sensor has shaft that sticks out of block and sensor bolts over shaft two wires.
I also have 05/05 manufacture date motor. I know that wiring harness changed in 12/05. So 05/05 knock sensor screwed into block with one wire.
Question is this:
On the 08/06 knock sensor does that shaft sending unit unscrew from block or press fit?, so I can screw in 05/05 sensor.
Toyota said need to use 05/05 wiring harness with 05/05 computer since they changed in 12/05,
I can not use 08/06 wiring harness as 05/05 computer does not read 08/06 wiring harness.
Putting 08/06 engine in 05/05 car.
___
Old Jun 9, 2020 | 02:57 PM
mrrcom's Avatar
Just looked on my block. You can unscrew it. A 5mm socket fits perfect on that end.
Old Jun 9, 2020 | 03:01 PM
rdjette's Avatar
Sweet..Thanks. This helps. Thought it screwed out but not sure, didn't want to break something.
Now I can finish putting the 05/05 wiring harness on the 08/06 motor to talk to the original 05/05 car and computer.
Thanks again.
___
Old Jun 9, 2020 | 03:13 PM
mrrcom's Avatar
yup np
ahhming888
Scion xA Aero & Exterior
Nov 18, 2019 02:54 AM
BigPinoyTC
Aug 7, 2010 04:53 AM
seaniscrazy
Jan 26, 2010 01:57 PM
punxnotdead
Nov 5, 2005 07:18 AM
iy0ga
Mar 29, 2004 10:12 PM
