Low compression after headgasket with timing set right?
I dont know what going on with this thing, Engine had a blown head gasket, replaced head gasket set timing and engine ran great. Check engine light came on showing a cam/crank correlation code P0016
I read about unlocking the intake cam phaser to get rid of this code. I Unlocked the cam phaser reinstalled and checked timing. Now the car will not start and has VERY low compression on all cylinders (showing 60-70PSI) I have been working on this thing for hours on end and cannot figureout what in the world is going on. I thought maybe I bent some valves somehow but I can removed the chain and close both valves on each cylinder with very minimal leakage (passed piston not valves)
I can also advance the intake cam gear by 4 teeth and get the cranking compression up to 110-120psi but it will not start.
I dont know how it was running great and now it wont build compression with the timing set correctly.
ANY help will be appreciated I have no where else to turn!
Just for refrence, I was taking the engine apart and found the Reluctor wheel somehow came apart and was just spinning freely on the crankshaft!!
No Idea how that happened but just incase anyone else ever runs across this issue they might wanna check that!
I have not had to get into that, but I assume the reluctor wheel is the crankshaft vibration damper and if it has fallen apart, you will obviously need a new one of those. I see from the valve adjustment pages that it is the basis of the valve timing, which is why you are not getting the valves timed properly.
I suspect it should be keyed to the crankshaft and the nut holding it on probably has a really high torque. Has the key failed? or is it just the wheel?
Unfortunately I do not have a complete manual so I can't help, but it is probably worth you buying access to those on-line manuals to find out how to fix it. Alldata is one of them, there are probably more (helminc). Buy a short time period and download as many pages as you think necessary is what I've heard. Have not done it though.
I got it fixed, the relucter wheel has a small washer like deal spot welded to it that has the slot for the keyway in it, the spot welds broke loose so it wasn't spinning with the crankshaft.
I lined it back up and welded it back together reinstalled everything and it fired right up!
Thanks for the reply but I should have said mine is the Scion xB 1.5L Toyota But the noise sound is what you’re saying. So far I installed new timing chain, starter,water pump,alternator, timing chain cover, crankshaft sensor. Lol. So I’m stuck to fix it now. Thanks again though. I’m now 100% it is what you described. But the wheel behind my lower timing sprocket is different and doesn’t move or jiggle. Regards Pappy.
garynkim
Jun 24, 2011 10:57 AM
DaygoSpecIST
Mar 11, 2009 07:18 AM
silverevo05
11
Nov 6, 2008 03:56 AM
ElChupacabra
64
Jul 30, 2006 04:36 PM
DikkaD
11
May 10, 2005 09:44 PM
