Maint light blinking
Old Nov 21, 2006 | 02:18 AM
bryandrry's Avatar
Default Maint light blinking
I did the search and found the same symptoms, but I had an oil change at 3K and the soln for the one who asked before said he was over his oil change limit. I have just hit 4500 miles on my 06 and the maint light blinks 6 times for about 15sec or until I move the car. It does this upon startup. I am taking it in to the dealer tomorrow, but does anyone know what could be doing this?
Old Nov 21, 2006 | 02:21 AM
web's Avatar
web
The could have forgot to clear the light so it was set for 4000 and it'll blink. Try resetting the light (key turned to on, odometer showing, hold fuel reset until all 000000) and set it to come back on at your next desired interval (perform same steps as reset and however many lines are left......1 line = 1000 miles......will determine the next time the light comes on.
Good luck.
Old Nov 21, 2006 | 02:22 AM
Max's Avatar
Max
It's normal. Don't waste your time going to the dealer unless you are going there for something else.
https://www.scionlife.com/forums/viewtopic.php?t=20749
Old Nov 21, 2006 | 02:23 AM
ProshopXB's Avatar
When you had your first oil change the maitnance required light was not reset... It was set from the factory to start going off at 4500 miles (to let you know an oil change would be needed soon)and would come on solid at 5000 miles meaning time for an oil change.. You can set when the MRL comes on 3k or 5k and others incriments..
Here is how to turn it off: https://www.scionlife.com/forums/viewtopic.php?t=20749
Old Nov 21, 2006 | 02:29 AM
bryandrry's Avatar
Thanks guys
I should have searched more.
I will try this in the morning
lsjimenez
Apr 3, 2015 01:32 PM
Crs22
Mar 23, 2015 08:49 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
GreatWhitexA
12
Nov 19, 2003 04:32 PM
BboXedin
Oct 13, 2003 07:21 AM
