need advice on high quality synthetic oil?
Originally Posted by javastan
... Don't waste your money on mobil 1. It isn't a true synthetic, it is made with a dyno base, a group three with pao additives,... Amsoil, Royal Purple, and Redline are a PAO base which is better.
Originally Posted by Mobil
Is Mobil 1 with SuperSyn Technology a fully synthetic motor oil?
Yes, it is. To meet the demanding requirements of today's specifications (and our customers' expectations), Mobil 1 with SuperSyn uses high-performance fluids, including polyalphaolefins (PAOs), along with a proprietary system of additives. Each Mobil 1 with SuperSyn viscosity grade uses a unique combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its specific application.
http://www.mobil1.com/USA-English/Mo...AQs.aspx#FAQs1
I pulled the following from their website. Again, they use the word "including".
M1 is a fine oil...nothing wrong with it at all. It is just that ot os 3 times as expensive as it should be. Some people will pay $600 for a pair of shoes just because of the name that is on them. Others pay $6/qt. for motor oil because of the same reason.
Question:
Response to Claims that Products Contain 'Mostly Mineral Oil'
I've seen claims of gas chromatograph analysis of Mobil 1 Extended Performance 5W-30 SM dated 10-06 that state it is "mostly mineral oil". Realizing that you cannot divulge your exact formulations, what do you say to the critics that claim you are using a high percentage of hydro processed mineral oil in Mobil 1 instead of the more expensive PAO or polyester base stocks?
-- Jeff Willett, St. Peters, MO
Answer:
Just like other companies, we do not discuss our product formulations for obvious proprietary reasons. Mobil 1 Extended Performance is formulated using a combination of high performance fluids including PAO, along with a proprietary system of performance additives. But in the end, it is also about performance. Mobil 1 is used by more Original Equipment Manufacturers than any other oil as factory fill in their vehicles. Also take note of the kind of testing we put our product through, including the Las Vegas field testing we recently completed. The Mobil 1 technology is also tested each weekend on the race track. In fact, more than 50 percent of all NASCAR teams use Mobil 1.
http://www.mobil1.com/USA-English/Mo..._Question.aspx
Mobil's site flatly says:
What more can they say?
Yes, it is...
Yes, it is...
And dont get me started of Mobils funding of global warming skeptics, shady foreign business practices, the Valdez oil spill, their human rights record .......
Here is a little lesson on synthetic oil. Turn your speakers on and listen you will learn!
http://www.redlineoil.com/products_m...=1&subcatID=14
Mobil-1 for me. This oil will last for at least 14K miles. I have pushed it to over 15K miles on one change before. No side effects aside from a slightly rough idle. Once changed, was smooth as butter.
[/quote]How can the oil affect the idle?[/quote]
I have no idea but it sure does. When I change the oil there is a definite difference between the dirty and clean.
There have been test done on Mobil 1 and they noticed the same thing especially when it starts getting close to 15K miles. The test showed the oil still holds up for that long, backed by a chemical analysis.
How did you do that?
and question about how oil affects idle? i'm wondering that too. i'm running mobil 1 and it has been working great. but since i've used it my idle plays. what i mean is some times it goes below 5k and gets rough than comes back up. and than it does it again after a few seconds. it does it pretty much everyday now. so whats going one. is it my oil? i'll try new oil and see. but i changed new plugs so that wasn't the problem.
-----------tom
I actually mean that when the oil gets dirty it will idle a little rougher.
My car has always idled a little funny, sometimes dropping the rpms to the point I think it will stall, especially when the AC is on.
Is there any third party information on the different synthetics available. I never really trust what manufacturers say about themselves, they want to make a sale.
Please post links if you have any.
In my opinion this is the best!
http://www.bobistheoilguy.com/
Take a look around in the forums.
Music City Scions
Originally Posted by wanachat15
i've been using full synthetic mobil one oil. and want to know what other brands people out there use. and what type of oil out there is really expensive but really really goooood?
------tom
------tom
checked out mobil1.com. it IS IN FACT made from PAO base! can now be used in any car from ZERO to over 70k miles. indeed, the list of autos using it as OEM equipment is quite ompressive!
I thought that this tread too wasnt going to start into a ____ing match. I had my hopes up until this page LOL. But the question is a loaded one, as everyone has their own different opinons.
I have used Mobil 1 for well over 15 years now, and havent had one problem. Thats countless oil changes on several different cars all from 100K+ miles to brand new. More recently i switch over to the Mobil 1 Extended Life and i get 15K miles out of it. At Wal-Mart is only a few dollars more ( still under $30 ) for 5 quarts and i use a quality oil filter. I use the blue PureOne filters, they run about $7 a pop. They have a rubber diaphram that keeps some oil in the can during start up, which i like.
JMO.
JMO.
I think the next oil change I may try some Amsoil oil and their Ea oil filter. The filters are supposed to be the best and I haven't heard any complaints about the oil. With the filters around $16 and oil around $8/qt, it's 1.5x to 2x as expensive for a change. Worth it if I were to follow their 1yr/25k mile service or 1yr/15k severe service. Still undecided though...
