Need help asap
Old Aug 2, 2008 | 03:00 PM
ScionTech1's Avatar
Default Need help asap
ok yesterday one of my belts on my 05 scion Xa moved off its plave having a hard time getting back on its not the belt thats on the top where u can adjusted on the bracket but the belt beneath that i need help trying to put back on does anyone have any suggestion need help asap
Old Aug 2, 2008 | 03:44 PM
Black_Sheep_xB's Avatar
you need to remove the upper/serp belt, then get to that one... it pays a shop 1.3 hours to do, so it should take some time.. this is out of the xB manual, same design
REMOVE GENERATOR V BELT
a) Loosen bolts A and B.
b) Release the belt tension and remove the belt.
REMOVE ENGINE UNDER COVER RH
REMOVE VANE PUMP V BELT
b) Release the belt tension, and remove the belt.
INSTALLATION
INSTALL VANE PUMP V BELT
a) Temporarily install the belt on each pulley.
INSTALL GENERATOR V BELT
ADJUST GENERATOR V BELT
a) Insert the adjusting bar between the engine RH mount bracket and generator. Push the bar towards the vehicle front to adjust the belt tension.
NOTICE: Do not insert the bar between the oil control valve and generator. It could damage the oil control valve.
b) First tighten bolt A, and then tighten bolt B.
Torque: 18.5 Nm (189 kgf-cm, 14 ft. lbs.) for bolt A
54 Nm (550 kgf-cm, 40 ft. lbs.) for bolt B
ADJUST VANE PUMP V BELT
a) Using the bar, adjust the belt tension.
b) First tighten bolt B, and then tighten bolt A.
Torque: 44 Nm (449 kgf-cm, 33 ft. lbs.)
CHECK DRIVE BELT TENSION
INSTALL ENGINE UNDER COVER RH
Old Aug 2, 2008 | 05:31 PM
jct's Avatar
jct
doing the PS belt is a p.i.t.a. its just hard to find a good place to find good spot to hold the ps pump tight while your tighten down the bolts i just used an old tire iron from the early 70's works good for me
Old Aug 2, 2008 | 06:47 PM
RETIREDCHARLIE's Avatar
CAN SOMEONE PLEASE HELP, I HAVE A XB 06, I GET SOME BAD SQUEAKING IN THE MORNING. SOME ONE TOLD ME TO LOOK AT TSB EG7026. I CAN NOT FIND IT ANYWHERE. CAN SOMEONE PLEASE GIVE ME AN IDEA WHERE I CAN FIND THAT AND OTHER XB 06 TSB'S. THANKS THIS IS DRIVING ME NUTS
Old Aug 2, 2008 | 07:19 PM
the best thing you can do, is gat an All Data account for the xB, I did, its 19.95 per year, for just one make and modele, aside from everything thats in the service manual, it also has part numbers, cost, labor times, and all the TSB's. The TSB's are added as they come out.
This is the one I found through All Data for the '06 squeal:
Engine - Engine Compartment Squealing Noise
ENGINE
EG031-07
Title:
ACCESSORY DRIVE BELT NOISE
Models:
'04 - '06 Scion xA & xB
June 20, 2007
Introduction
Some 2004 - 2006 model year Scion XA and xB vehicles may exhibit a squealing noise coming from the engine compartment during vehicle operation. The generator drive belt tension specification has been updated to correct this condition. Please use the following repair procedure to address customer concerns.
Belt part number for this TSB: 90916-02556
Repair Procedure
1. Verify that the noise is coming from the generator V-belt.
NOTE :Replace the generator V-belt if there is any sign of fraying, scoring, or glazing on the belt.
2. Remove and replace the generator V-belt. Updated generator V-belt specification:
Refer to the Technical Information System (TIS):
^ 2004 or 2005 model year Scion XA or xB Repair Manual, Engine/Hybrid System - Engine Mechanical - "1NZ-FE: Drive Belt: Replacement"
^ 2006 model year Scion XA or xB Repair Manual,
^ Engine/Hybrid System - Engine Mechanical - "1NZ-FE Engine Mechanical: Drive Belt: Removal"
^ Engine/Hybrid System - Engine Mechanical - "1NZ-FE Engine Mechanical: Drive Belt: Installation"
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Old Aug 2, 2008 | 07:35 PM
Default thank you
thank you sir, i will have to do that because i like to know about my cars. please have a good day. retiredcharlie
Old Aug 2, 2008 | 11:23 PM
ScionTech1's Avatar
Default thanks
you guys are F@#&N awsome i appreciate that got another question when i put my scion into first and so on it over revs and wont pick up speed till the last minute could that be clutch or something else i only had the car for 3 years and reached 60 thousand miles everyone keeps saying its my clutch or my pressure plates I just want a second opinion or a third
Old Aug 3, 2008 | 03:35 AM
second/third and fourth opinions below:
clutch
clutch
& Clutch
Old Aug 3, 2008 | 03:37 AM
Default Re: thank you
Yeah.. its great to have access to.. & your welcome
www.alldatadiy.com
danielv
Aug 26, 2015 07:14 PM
vancouverray
Scion xB 2nd-Gen Wheel & Tire
Aug 10, 2015 10:20 PM
JLOVE1
Jul 31, 2015 02:40 AM
pdxgen2
Mar 14, 2015 01:56 AM
