need help: problem with intake I think
Ok I installed an injen short ram intake couple months ago... it was working fine... Now when im in a complete stop... About 30 seconds later feel like the engine is choking... Meanin feel like air not goin into the engine,I hear the hissing noise goin on and off, the rpm almost reach to 0 then back to almost 1...then when I putem back to neutral then to drive its ok... Then later it happen again... Not as worst though... I reinstall the intake again... Still the same situation... Any suggestion? I was thinking of recharging the filter... Thanks
Ok... I installed the stock intake... Eci reset... Clean the maf sensor with electronic cleaner... Drove around... Died out around 10 miles... Now gotta wait about 100 more miles... Cause thats when the pattern on vsc, trac off, and check engine light comes on... Hopefully its not the intake related...
Well went to the dealer and they said that the gas cap wasn't on good... And they suggested that when fillin up gas... Don't top it off... So hopefully thas been fixed... Thanks for the help
Ok this month I was doin an experiment on the lights.... After went to the dealership... They sed it was the gas cap... After 50 miles... Lights came on... After I got me a locking gas cap... Lights came on after 50 miles...so all I do now is reset the efi by taking out the fuse... Wait 30 second... Then put it back in... Still the same... Got these codes from the obdII scanner...
1. P0441 evaporative emission control system incorrect purge flow
2. P0442 evaporative emission control system leak detected (small leak)
3. P0446 evaporative emission control system vent control circuit malfunction
Also when I fill up the tank, I stop once it clicks... I stop fillin... Any help? Thanks
wiltonhall
Jun 23, 2025 10:09 PM
hotroddelux
Dec 3, 2014 11:33 PM
