New Owner
Old Aug 14, 2009 | 09:33 AM
sajack's Avatar
Default New Owner
I just purchased a 92,000 mile '05 xB. I won't be picking it up till the end of August, so haven't looked at the service recommendations yet. This is a one owner that had routine oil changes and has had a brake job.
What do I need to do as far as normal maintenance? Spark plugs, auto. trans. service, coolant systtem flush, etc.? We're going to be putting about 30,000 miles/ year on this xB, so it's going to be a high-miler and I want to take care of it.
Old Aug 14, 2009 | 10:20 AM
bB384's Avatar
IV ACE
For the most part this car fairly low maintenance. Since you're the second owner I would do the following just so you have the peace of mind that everything is up to par.
Once you pick up the car just do the following;
- Oil change w/ filter (I recommend a good synthetic oil)
- Check/Replace air filter
- Flush transmission fluid (Make sure you use OEM or equivalent)
- Replace spark plugs (I recommend NGK V-Power BKR5EYA)
- Flush brake fluid & inspect brakes
- Check/flush coolant (Again try to use OEM or equivalent)
LilWolf
Feb 1, 2017 09:38 PM
Denzel
Oct 14, 2015 10:15 PM
akarnofel
Scion xB 2nd-Gen Wheel & Tire
Aug 26, 2015 07:49 PM
formerpraetorian
Jul 22, 2015 01:05 AM
stenger
Jul 15, 2015 01:03 AM
