Oil pump
Old Mar 23, 2013 | 04:23 PM
civicjerc's Avatar
Default Oil pump
Anyone know how to tell if the oil pump is bad? My xb seems to be with high oil pressure and there's a crazy noise coming from the timing chain side of the motor any help will be appreciated
Old Mar 23, 2013 | 04:29 PM
civicjerc's Avatar
Oil pressure is above 90 and it's knocking in the front cover
Old Mar 24, 2013 | 10:10 PM
buickid's Avatar
Usually the service manual will instruct you to measure the clearances inside the oilpump. If oil pressure is high and theres a loud knocking noise, perhaps one of the oil passages has clogged. Do you do regular oil and filter changes? The knocking noise could be massive rod knock from lack of oil. If it is... engine rebuild... Do not continue to drive it. Take it to a mechanic.
Old Apr 7, 2013 | 03:16 PM
civicjerc's Avatar
Yeah it gets regular oil changes. They think its the pump having it replaced thanks
dgm458
Scion xD Drivetrain & Power
Aug 24, 2015 04:44 AM
rrtxdrvr
May 22, 2015 03:58 AM
tom0613
Mar 7, 2015 05:59 PM
cid_mcdp
Jan 5, 2015 02:45 PM
