Once and for all, 80 MPH at 4000 RPM is this Normal?
Old Dec 31, 2017 | 06:05 PM
Juanvelez88's Avatar
Default Once and for all, 80 MPH at 4000 RPM is this Normal?
I just bought a beautiful 2004 manual Scion xA,I already did a full tune up ..
-PCV valve
-Full synthetic oil change
-Air filter
-Iridium spark plugs
-Clean Air Mass Sensor
-Clean the trothle
-Checked transmission oil
-Checked diferential oil
-Repalced thermostat
-Flushed the radiator
and when I drive it on the freeway at 80 MPH the tachometer gets all the way up to 4000 RPM.
Is this normal? If not how can I fix it?
____
Old Dec 31, 2017 | 06:55 PM
MileHightC's Avatar
Super Moderator
SuperMod
Completely normal based upon the five speed's gearing...
Old Dec 31, 2017 | 08:14 PM
2stroked's Avatar
Exactly what both of my 2006 xB 5-speeds turn at 80 MPH. How can you fix it? Drive slower - or faster.
Old Dec 31, 2017 | 08:29 PM
Default Thats what I needed to know ..
I just wanted to know because it feels like Im putting to much pressure in my engine but if thts how it is then I feel more comfortable
Old Jan 1, 2018 | 01:11 PM
2stroked's Avatar
Yea, unfortunately, it's perfectly normal. Mine screams along just like yours. I've often said that I wish they put a sixth gear in the manuals. Trust me though, the engine will run pretty much forever if you take care of it.
Old May 13, 2020 | 05:34 PM
Birsan's Avatar
Hi, I drove today on highway. I like the engine noise to one point. In the past I notice in neutral Scion xB 2004 usually with new clean regular oil gets to about 650-750 RPM. When the regular oil need change, in neutral speed will have RPM (revolutions per minute) close to 1,000 RPM. I replace the oil with full synthetic few years ago (The oil filter, need to be now special, compatible with the synthetic oil). So, on full synthetic oil, I get all the time 650 to 750 RPM in neutral. At 2,800 RPM the car will have like 65 Miles per hours. At 3,200 The car will have 75 miles per hour. To get 80 Miles per hour will be less than 4,000 RPM in my car for some reason. Also, I found that if I drove between 37 and 49 Miles per hour and took my leg from the gas pedal, the transmission gets some how disconnected and the RPM's will drop to about 800-900 RPM. The car will run in very efficient mode. Best speed to get more miles per gallon looks like is at 55miles per hour. I replace twice my transmission fluid and filter, to get a smooth engine RPM's. Never get a transmission flush on old models!.
Old May 20, 2020 | 01:51 AM
Birsan's Avatar
Old May 20, 2020 | 01:57 AM
Birsan's Avatar
Hi, looks like is not perfectly normal in 2020. Scion xB 2004 at 80 Mile per hour have RPM shows 3,250. Can some one please let me know what the manufacturer documents have listed for this behavior? Thank you.
Old May 20, 2020 | 03:42 AM
JakeAut0's Avatar
Hi, it looks like is not perfectly normal in 2020. Scion xB 2004 at 80 Mile per hour have RPM shows 3,250. Can someone please let me know what the manufacturer documents have listed for this behavior? Thank you.
This behavior is completely normal for a 2004 Scion xB because of the transmission gearing.
From: https://www.clubxb.com/threads/auto-...l.27638/page-2
Calesta - Yup, the gearing is taller on the auto in 4th than the manual is in 5th.
Code:
Gear | Manual | Auto
Code:
1st | 3.54:1 | 2.84:1
2nd | 1.90:1 | 1.55:1
3rd | 1.31:1 | 1.00:1
4th | 0.96:1 | 0.70:1
5th | 0.81:1 | –
R | 3.25:1 | 2.34:1
FD | 4.31:1 | 4.15:1
Hopefully, that lined up correctly... so that gives you this for overall drive ratios in each gear:
Code:
Code:
1st | 15.25 | 11.66
2nd | 8.18 | 6.43
3rd | 5.64 | 4.15
4th | 4.13 | 2.90
5th | 3.49 | 0
R | 14.00 | 9.71
Those are just truncated... not like everything is super exact anyway. So based on the stock 185/60-15 tire size, the actual speed (not accounting for the error in the speedometer) in each gear would be:
Code:
Code:
rpm man1 man2 man3 man4 man5
1000 5 9 13 17 20
2000 9 17 25 34 40
3000 14 26 38 51 61
4000 19 34 50 68 81
5000 23 43 63 85 101
6000 28 52 75 102 121
7000 32 60 88 119 142
rpm auto1 auto2 auto3 auto4
1000 6 11 17 24
2000 12 22 34 49
3000 18 33 51 73
4000 24 44 68 97
5000 30 55 85 122
6000 36 66 102 146
7000 42 77 119 170
Or for a direct comparison for highway cruising purposes:
Code:
Code:
rpm auto4 man5
1000 24 20
2000 49 40
3000 73 61
4000 97 81
5000 122 101
6000 146 121
7000 170 142
Which translates down to this:
Code:
Code:
speed aut4(rpm) man5(rpm)
10 411 494
20 823 989
30 1234 1483
40 1645 977
Code:
50 2057 2472
60 2468 2966
70 2879 3460
80 3291 3954
90 3702 4449
100 4113 4943
All approximate of course.
But the manual will let you use your power more efficiently as you accelerate because of the tighter ratios, so you'll spend less gas (and less time) going from 0-60mph with your foot on the floor driving the manual.
Old May 20, 2020 | 06:02 AM
Birsan's Avatar
@ JakeAut0, your posting is extremely clear. My trany is auto. When starting from zero speed, I use the gas pedal up and down to save the gas and to go fast from the first gear to the next gear.
Also, what I find that if the car driving at 70 MPH on neutral, the gear put in drive is smart. He chose the #5.
Question: If moving the gear from Drive to Reverse, how much time need for a good transmission to take?( in seconds). So, the reverse RPM will be 650?
Thank you.
Last week one of my neighbors had a problem with the car in the morning. He have a new car. The new cars are made with biodegradable materials and the rats are eating them. Scion xB 2004 have the transmission sensors and the wires made the old fashion, will last forever.
Old Sep 6, 2020 | 08:39 PM
TNhands's Avatar
Default Flushing vs. Replacing
Originally Posted by Birsan
........ I replace twice my transmission fluid and filter, to get a smooth engine RPM's. Never get a transmission flush on old models!. "
Flushing?? Never flush but you have replaced the transmission fluid twice?
I'm about to attempt this for the first time. What's the difference ? I thought it was the same thing.
___
Old Sep 7, 2020 | 02:10 PM
Birsan's Avatar
@TNhands , Hi the automatic transmission have a complicate business inside. The red color fluid is circulating inside and also going in the front radiator to get a lower temperature. Many parts are depending on this transmission fluid. According with Scott Kilmer from youtube never attempt to flush an old automatic transmission. When the flushing machine is doing the work, puts lots of pressure inside to remove all the old red color liquid. Not all old transmissions will "survive" to this treatment. By replacing the transmission filter, like half of the red (or black) color will needed to be replace. After the second filter replacement looks like other 25% will be replace. In this way the transmission liquid will be replace using the natural gravity, no other power sources that may damage the transmission. Today my Scion xB 2004 have a nice driving sound, changing the speeds up and down with no problems. Also to help the transmission to work in good conditions, be sure your throtle is clean (the car radiator coolant liquid have free passing way), and on the other side the cylindrical magnet is turning easy. This way the oxygen and the returning exhaust gasses can do their work too. I can not talk about prices here because my post will be remove.
Old Jul 7, 2021 | 09:49 PM
TNhands's Avatar
good to know. thank you.
Old Jul 7, 2021 | 10:37 PM
drizzoh's Avatar
Not to threadjack, but I've never had an issue doing a drain + refill on a high mileage transmission but flushes are something you generally want to avoid. Doing a drain and refill every 30k is best practice and greatly helps the performance and longevity of your trans. If it has an in-line filter, I typically replace every other fluid change (every 60k). Generally they're pretty easy to do in your garage and keeps everything in the gearbox happy. Might be a little overkill for some, but I drive pretty hard and never had a trans blow up - some upwards of 300k miles.
Re: the initial question, on those older 5speeds 4k @ 80mph is normal. Very happy my tC2 is a 6MT. Still a little over 3k @ 80 but beats 4k.
Old Jul 8, 2021 | 05:23 PM
2stroked's Avatar
Please do not consider anything posted by Birsan to be correct. You would be in a world of hurt if you used most of his advice.
Old Jul 8, 2021 | 05:38 PM
drizzoh's Avatar
+1
Old Jul 8, 2021 | 06:05 PM
MileHightC's Avatar
Super Moderator
SuperMod
Pretty solid advice right there...
Old Jul 15, 2021 | 09:44 AM
Low_Kei's Avatar
9 times out of 10, Scotty Kilmer is wrong, and so is Birsan… But this time, flushing a high mileage transmission being bad is actually correct. Draining and refilling is okay, as well as changing the transmission filter (This is for automatic transmissions of course), but flushing a high mileage automatic is a bad idea because any of the friction material could be flushed out, which results in slipping and eventually failure of an automatic transmission. I don’t know why anyone watches Kilmer’s videos for anything other than a good laugh at his idiocy. Mechanics and car enthusiast alike that know what they are doing do not take him seriously.
Old Jul 16, 2021 | 05:34 PM
MileHightC's Avatar
Super Moderator
SuperMod
Originally Posted by Low_Kei
I don’t know why anyone watches Kilmer’s videos for anything g other than a good laugh at his idiocy. Mechanics and car enthusiast allure do not take him seriously.
I've got my suspicions that he's also a raging alcoholic as he always sounds borderline hammered in his videos.
Old Jul 27, 2021 | 01:41 PM
blumontag's Avatar
Kilmer is hilarious, and even more so at 3/4 speed! When you're ready to watch a YouTube video, click on the little gear icon (settings) to change
the playback speed to .75
