Perrin crank pulley review - my 2 cents
Old Jul 10, 2005 | 04:27 AM
squirrel's Avatar
Originally Posted by xmetalx
i will probably be waiting till the unorthodox pullys come out, they will probably be lighter and give you more performance
I'm waiting also. I may go with each as I have two powerplants sitting here waiting for work.
Old Jul 10, 2005 | 06:22 AM
KangaRod's Avatar
I just went for the Perrin now, for the price >$150, you can always chalk it up if the Unorthodox is that much better.
Old Jul 10, 2005 | 04:03 PM
BeQuietAndDrive's Avatar
I am very unsure of aftermarket crank pulley's. While they may or may not be right, I've read quite a lot of information on engine harmonic's and balancing, and how adding a lighter weight pulley throws the balancing off, leading to undue stress on the engine. While some comapnies use the crank pulley as a harmonic balancer, some do not. Anyone wish to contact Toyota in regards to if it is a balancer or not?
Old Jul 10, 2005 | 05:02 PM
KangaRod's Avatar
Perrin states clearly on their website that their pully will not cause engine damage or premature bearing wear. That is a pretty bold statement to be making. But I trust them
Old Jul 10, 2005 | 05:09 PM
Simplyscion's Avatar
Team No Limitz
Its not gonna cause damage...its pretty much the same pulley as the stock one just lighter in weight!
Old Jul 10, 2005 | 05:30 PM
eggie's Avatar
Someone did contact Toyota at one time and they stated that the engine is internally balanced.
Old Jul 11, 2005 | 01:13 AM
mikochu's Avatar
Knowing their history with their Scion parts...I wouldn't trust them...but only time will tell.
Old Jul 11, 2005 | 05:06 AM
The_Zeeness's Avatar
I'm unaware, what problems have there been?
edit: oh, are you talking about the V1 issue?
Old Jul 11, 2005 | 05:11 AM
mikochu's Avatar
both the pulley and fuel rail fitment issues...
Old Jul 11, 2005 | 05:42 AM
Guest
Guest
Posts: n/a
Although it was good to see that they responded to the problem, I know it took a while. But the problem was resolved. I am sure they have learned from thier mistakes.
Old Jul 11, 2005 | 07:13 PM
Team No Limitz
Perrin makes good products, both issues were fitment issues, but once the problem was rectified, these products work flawless...Id like to see one person on this forum that has something bad to say about their V2 pulley. I have both the pulley and the rail on my car and have no problems w/ either
Old Jul 12, 2005 | 12:03 AM
KangaRod's Avatar
what benefits does the fuel rail offer for the average driver?
Old Jul 12, 2005 | 12:30 AM
Munch's Avatar
None.................with a boosted car that's another story.
Old Jul 12, 2005 | 05:08 AM
squirrel's Avatar
Fitment ISSUES, don't you mean?
Old Jul 12, 2005 | 05:30 AM
clear_bra_guy's Avatar
the throttle response is definatly snappier with the pulley !!!!!!!! great buy excellent addition to the box
if you dont add larger injectors there is no differance, there is a port on the end of the rail though, that you can connect your nitrous to, the added fuel in the Perrin rail wiil fill the injectors and run the N2O without leaning out. we do know which injectors to bump up to just waiting for them to come in.
Old Jul 12, 2005 | 05:55 AM
Guest
Guest
Posts: n/a
And there you go. :D
Old Jul 12, 2005 | 05:56 AM
if your keeping your car stock yes but if your a customizer no problem
the pulley needs no mods
1. loosen alt
2. remove bolt
3. remove pulley
4. install neww pulley
5. put ps belt on
6. tighten bolt
7. tighten alt
8. drive
fuil rail
the rail hits here
cut here
30 seconds later. . .
finished no leaks no fuss
Old Jul 12, 2005 | 08:31 PM
squirrel's Avatar
Thanks for the pictorial Jim!
Old Jul 13, 2005 | 05:07 AM
KangaRod's Avatar
it looks pretty bling bling at least.
Old Jul 13, 2005 | 05:13 AM
it doesn't hurt that I got them to sponsor us either.
