Perrin crank pulley review - my 2 cents
Old Jul 13, 2005 | 06:13 AM
  #41
mikochu's Avatar
Originally Posted by squirrel
Originally Posted by mikochu
both the pulley and fuel rail fitment issues...
Fitment ISSUES, don't you mean?
wha?
Old Jul 13, 2005 | 06:18 AM
  #42
xmetalx's Avatar
yea that rail is bling friggen bling.
Old Jul 13, 2005 | 06:32 AM
  #43
ScionxR's Avatar
I had problems loosening the bolt for the pulley anfd gave up. Now its a carpet decoration in my room. If you loosen the alternator does that relieve tension and make the bolt easier to remove?
Old Jul 13, 2005 | 03:31 PM
  #44
clear_bra_guy's Avatar
no you should do the Alt after the bolt. breaker bar, and a screw driver , to hold the pulley in place the bolt is like 3-4 inches long and has locktight all over it.
Old Jul 14, 2005 | 02:28 AM
  #45
gnar-de-gwar's Avatar
sooooo what if engine mod wise all i want to do is CAI, header, and exhaust? does this mean i'd have to get a new fuel rail? I'm not adding nitrous or turbocharging it or anything so adding one would be pointless, right?
Old Jul 14, 2005 | 03:22 AM
  #46
TXboxdriver's Avatar
not "pointless"
they will give you a few points on the judging sheet for it!
Old Jul 14, 2005 | 03:34 AM
  #47
xmetalx's Avatar
yea it would be pretty lame. But if you were to do turbo in the future it would be a nice step.
Old Jul 14, 2005 | 03:41 AM
  #48
eggie's Avatar
Originally Posted by TXboxdriver
not "pointless"
DOn't think you'd see it under the cover...
Old Jul 14, 2005 | 05:31 AM
  #49
KangaRod's Avatar
not "pointless"
no way I'd hack up my carbon fiber cover (if I had one LoL)
Old Jul 14, 2005 | 06:57 AM
  #50
Keep in mine this is just a first step in tapping more performance from a certain motor, the larger fuel rail will allow you to add larger injectors for more performance . . . do you have to? no, but like in any circle some people push the envelope and some dont, and thats ok either way. It's whatever your into. The info provided here is just so everyone can be on the same learning curve. we know how to move from a 200cc injector to a 250cc with this rail and factory parts kinda cool if you think about it, this all from sharing info with each other here on the forums.
and why would you cut anything this is a performance upgrade not a bling
Old Jul 14, 2005 | 05:11 PM
  #51
Simplyscion's Avatar
Team No Limitz
I am running the rail w/ upgraded 2zz injectors for the turbo setup...the rail is pointless unless you upgrade the injectors, or as clear bra guy said to add nitrous to the setup. I have my fuel pressure regulator running off the end of my rail.
Old Jul 14, 2005 | 05:31 PM
  #52
Guest
Guest
Posts: n/a
Got a pic? I wanna see., :D
Old Jul 14, 2005 | 05:39 PM
  #53
Team No Limitz
dont have a digital camera(i know im slackin)...ill see what i can do this week though, grab my parents camera w/out them knowing...i could always take a video and stream it on here i actually have a video camera
Old Jul 14, 2005 | 05:43 PM
  #54
Team No Limitz
heres a photo courtesy from Stu (lastlookcustoms)
Old Jul 14, 2005 | 05:45 PM
  #55
squirrel's Avatar
If one does not plan on adding more than an intake, header and exhaust, then an upgraded fuel rail is pointless.
No, it cannot be seen unless you remove your engine cover for shows.
BUT, if you plan on adding forced injection, whether it be thru a turbo, or supercharger application, then it is highly recommended along with higher flowing injectors.
One route for the injectors are the 2ZZ which bolt right in. I'm looking at another set, but the head needs slight machining. I may run one powerplant w/ the 2ZZ injectors and run w/ this other manufacturer.
There are a few other items that you may want to consider w/ the fuel delivery system, but I won't go into it here.
This is mainly a discussion about the fuel rail.
Old Jul 14, 2005 | 06:35 PM
  #56
Guest
Guest
Posts: n/a
Now that looks cool, :D Thanks for the pic Simplyscion!
Old Jul 14, 2005 | 06:50 PM
  #57
Team No Limitz
I dont understand...the picture shows up when i preview it but when i submit the post it will show up then disappear...i edited it like 3 times trying to fix the problem but heres the link to the website...just click on one of the pictures and then click on the gallery for the turbo pics
http://lastlookcustoms.com/modules/x..._004.sized.jpg
Old Jul 14, 2005 | 06:52 PM
  #58
squirrel's Avatar
Vito, I can see it everytime I come back to the thread.
Old Jul 14, 2005 | 06:55 PM
  #59
Team No Limitz
I dont understand it...i cant view it for some reason...never had this problem before
Old Jul 14, 2005 | 07:00 PM
  #60
squirrel's Avatar
