Perrin Pulley Installation Guide
For those who did this, the alt bolt on top is easy but the one on the bottom is directly below the top one. Correct?
Second, is it required to have both bolts on the PS pulley loose or just the one on the bottom.
I think I'm a wuss cause those bolts are on there tight as a frogs as$!!!
Originally Posted by frogbox
hope this wasn't a personal remark
I finished the Perrin Pulley install and I went for a drive of about 13 miles. It doesn't make any major increase in "ummfff" but it does help going up hills and such; which is what I was looking to accomplish. I'm not entirly sure it is worth the all the clams, but it is nice.
Originally Posted by Psyco565
...compared to my intake & exhaust...
heh, I really have never paid attention to my mpgs, I love to drive spiritedly around the back roads. My car is deffinately fun factor all over it. I guess it would help a little, it was crazy how much heavier the stock pulley was when you hold them both. And usually when you slap a intake and exhaust on, you'll want to drive around fast with the windows down just loving to hear it.
before breaking the alternator adjustment bolts i match marked the alternator against that adjustment bracket. it moved about an 8th inch. i could not get it back to the original position. will it be a problem?
This looked like a fairly straightforward mod but I can't figure out
1) how do you get the crank pulley from turning when you try to wrench it...the tech post says a screw driver betwenn the puley spokes...not doing it for me
2) How do you get to the PS pulley tensioner bots? Any suggestions on type of wrench? Is it possibe to take the crank pulley off without loosenling the PS belt?
Any tips would be appreciated. Most people seem to relate that this is an easy install, but after spending a few hours on this I am ready to ask a dealer to do it for me!
I have major problem getting the crank pulley off today even with power tool. I also notice there's a tiny mark on the stock Crank Pulley, what's it for? I don't see this mark on the Perrin unit. Any1 knows how much I need to torque down the crank pulley bolt after installation? Thanks
Anyone want to buy mine - Silver, new in box!
Questions: will an impact wrench socket fit between the crankshaft bolt and the inner fender wall? Or do you need a socket U-joint? How big is that gap between the crankshaft bolt and the fender wall? In the other pictures, it doesn't look like the crankshaft bolt is lower than the fender wall, so it seems like an impact wrench couldn't get in there.
Suggestion for craking the crank bolt loose. Crack it loose before you lossen the blet or take ot off. The extra drag helps to keep the engine from turning over. You can check to see id you can have a buddy jam one of the pully from the top while you break the crank bolt loose. I have had to deal with this on many cars and its always a pain, good luck.
I went to my Toyota dealer to see what was involved in istalling the pulley...
I showed the mechanic the new Perrin Pulley & he had a puzzled expression as he looked at it. He said there is no "keyhole" to "lock it in place"...
He also said there was no "rubber ring" to "harmonically balance the pulley". I know that our cars (xA & xB) are NOT harmonically balanced from what I've read here on Scionlife.
I'm thinking this guy has not done a pulley install on our cars yet. But he suggested calling Perrin to make sure all the parts are present. I'd like to know what is up before I call Perrin...
With what I've heard about peoples pulleys falling off I'd rather have the dealer or another shop do it since it's only an hours labor for cost $$$.
If you (and the Toyota mechanic) take a closer look at your pulley you should see a small hole right next to the larger hole in the center of the pulley. This does the same job as a keyway on other pulleys. This is also where most of the people that have had issues with aftermarket pulleys have had their problems. (Not that this is a large number.) The standard pin can shear. But different people have found creative ways to address it.
And you correct on the fact that the 1NZ-FE is internally balanced and does not require external balancing or dampening.
